Holy Stone HS720 Rear Right Arm Replacement
  1. Holy Stone HS720 Rear Right Arm Replacement, Remove the Battery: step 1, image 1 of 1
    • Press down on the button and pull out the battery, to reveal 2 hidden screws.
    Ask FixBot
  2. Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: step 2, image 1 of 3 Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: step 2, image 2 of 3 Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: step 2, image 3 of 3
    • Remove the 2 screws located under the battery
    • Remove the 2 screws on the sides of the drone, one on each side
    Ask FixBot
  3. Holy Stone HS720 Rear Right Arm Replacement, Remove the top cover: step 3, image 1 of 2 Holy Stone HS720 Rear Right Arm Replacement, Remove the top cover: step 3, image 2 of 2
    • Gently pry on the top plastic cover to gain access to the main board.
    • There are 2 cables running from the back of the cover, do not accidentally tear them
    • Unplug the 2 cables, by gently prying on them, and remove the top cover of the drone
    Ask FixBot
  4. Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: step 4, image 1 of 3 Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: step 4, image 2 of 3 Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: step 4, image 3 of 3
    • Look closely at the images and locate the 7 wires that are connected to the arm
    • Take a photo of the board, so that you can resolder them back correctly later
    • Desolder the 7 wires
    Ask FixBot
  5. Holy Stone HS720 Rear Right Arm Replacement, Remove the foot: step 5, image 1 of 1
    • Remove the 2 screws that attach the rear right foot of the drone
    • Take the foot off, to reveal the arm spring
    Ask FixBot
  6. Holy Stone HS720 Rear Right Arm Replacement, Remove the arm: step 6, image 1 of 2 Holy Stone HS720 Rear Right Arm Replacement, Remove the arm: step 6, image 2 of 2
    • Pry out the white plastic piece, to free the arm. (note: there are no screws holding it in)
    • Slowly pull the arm out, along with the wires connected to it
    Ask FixBot
    • Repeat the steps in reverse order to reassemble the drone
    Ask FixBot
Hope this helped :)
ugnoT
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 744
