Holmes Table Fan 12" Fan Blade Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
112
All Time:
2,624
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
As you walk through this guide you will successfully achieve your attempt to replace the blade of your 12 inch Holmes table model #32510380. Although a simple repair be aware that this task may take more force than usual to attain your final product.
This link is the manual that helped aid in identifying parts and helped us deconstruct the fan.
12084_12_Table_Fan_IM.pdf (getholmesfans.com)
    1. Holmes Table Fan 12" Fan Blade Replacement, Fan Blade: step 1, image 1 of 1
      • Unclip the fan grill from the base.
      • May take some force.
      Ask FixBot
    2. Holmes Table Fan 12" Fan Blade Replacement: step 2, image 1 of 1
      • Remove the grill.
      Ask FixBot
    3. Holmes Table Fan 12" Fan Blade Replacement: step 3, image 1 of 1
      • Unscrew the blade cap.
      • Blade cap is the black disk in the center.
      • Turn to the right for loosening.
      Ask FixBot
    4. Holmes Table Fan 12" Fan Blade Replacement: step 4, image 1 of 2 Holmes Table Fan 12" Fan Blade Replacement: step 4, image 2 of 2
      • Lift the blade off of the motor shaft.
      Ask FixBot
    5. Holmes Table Fan 12" Fan Blade Replacement: step 5, image 1 of 1
      • Insert a new blade on the motor shaft.
      • The motor shaft is the long metal screw in the middle.
      Ask FixBot
    6. Holmes Table Fan 12" Fan Blade Replacement: step 6, image 1 of 1
      • After the blade is back on, reattach the blade cap.
      Ask FixBot
    7. Holmes Table Fan 12" Fan Blade Replacement: step 7, image 1 of 1
      • Screw the blade cap back on.
      • Turn to the left for tightening.
      Ask FixBot
    8. Holmes Table Fan 12" Fan Blade Replacement: step 8, image 1 of 1
      • Clip the fan grill back on the base.
      Ask FixBot
7 other people completed this guide.
Emily Contreras
346 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 112
All Time: 2,624
