Holmes HEH8031 Fan Blade Assembly Replacement
  1. Holmes HEH8031 Fan Blade Assembly Replacement, Fan Blade Assembly: step 1, image 1 of 2 Holmes HEH8031 Fan Blade Assembly Replacement, Fan Blade Assembly: step 1, image 2 of 2
    • Identify that you have the Holmes HEH8031 heater. The model number is on the bottom of the unit.
    Ask FixBot
  2. Holmes HEH8031 Fan Blade Assembly Replacement: step 2, image 1 of 1
    • Place the heater so the rear housing is facing you.
    • Remove the eight (8) 1 cm coarse-threaded screws around the perimeter.
    • Remove the two (2) 7 mm machine screws in the center.
    Ask FixBot
  3. Holmes HEH8031 Fan Blade Assembly Replacement: step 3, image 1 of 3 Holmes HEH8031 Fan Blade Assembly Replacement: step 3, image 2 of 3 Holmes HEH8031 Fan Blade Assembly Replacement: step 3, image 3 of 3
    • Using your fingers, pry bottom corner of housing open from bottom to top.
    • Wiring remains connected at the top of the front and rear of the housing. Don't pull too hard or you will disconnect the wires.
    • Fan and rotor assembly are not connected to the housing. They will be loose.
    Ask FixBot
  4. Holmes HEH8031 Fan Blade Assembly Replacement: step 4, image 1 of 2 Holmes HEH8031 Fan Blade Assembly Replacement: step 4, image 2 of 2
    • Turn the fan blade assembly over so blades are facing up.
    • Locate the four (4) metal tabs that connect the blade assembly to the rotor.
    Ask FixBot
  5. Holmes HEH8031 Fan Blade Assembly Replacement: step 5, image 1 of 2 Holmes HEH8031 Fan Blade Assembly Replacement: step 5, image 2 of 2
    • Using the pointed metal spudger, bend each of the four (4) metal tabs toward the rotor shaft.
    • Bend tabs only far enough to clear the blade assembly so they can be easily bent back later to reattach the new blade assembly.
    Ask FixBot
  6. Holmes HEH8031 Fan Blade Assembly Replacement, Remove blade assembly: step 6, image 1 of 3 Holmes HEH8031 Fan Blade Assembly Replacement, Remove blade assembly: step 6, image 2 of 3 Holmes HEH8031 Fan Blade Assembly Replacement, Remove blade assembly: step 6, image 3 of 3
    • Lift the blade assembly off the rotor shaft.
    • You may need to wiggle the blade assembly slightly to free it from the rotor.
    • When reassembling the unit, you must replace the two (2) 7 mm machine screws that connect the rotor assembly to the housing before replacing the coarse-threaded screws. Aligning the 1 cm machine screws may take some finesse.
    Ask FixBot
Corinne Renguette
152 Reputation
1 Guide authored
iFixit, Team 1-1, Gismondi Spring 2016 Member of iFixit, Team 1-1, Gismondi Spring 2016
FIX-GISMONDI-S16S1G1
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 1,062
