Introduction
If the buttons on your humidifier aren't working, follow this guide to access the control panel. This will show a simple step-by-step process of how to remove your control panel for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace the control panel.
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
