Hitachi CP-X440 Power Supply Unit Replacement
  1. Hitachi CP-X440 Power Supply Unit Replacement, Motherboard: step 1, image 1 of 1
    • Turn the projector upside down so the bottom is facing up.
    • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
    Ask FixBot
  2. Hitachi CP-X440 Power Supply Unit Replacement: step 2, image 1 of 2 Hitachi CP-X440 Power Supply Unit Replacement: step 2, image 2 of 2
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
    • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
    Ask FixBot
  3. Hitachi CP-X440 Power Supply Unit Replacement: step 3, image 1 of 2 Hitachi CP-X440 Power Supply Unit Replacement: step 3, image 2 of 2
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
    Ask FixBot
  4. Hitachi CP-X440 Power Supply Unit Replacement: step 4, image 1 of 2 Hitachi CP-X440 Power Supply Unit Replacement: step 4, image 2 of 2
    • Gently remove the cables from their white connectors on the circuit board.
    Ask FixBot
  5. Hitachi CP-X440 Power Supply Unit Replacement: step 5, image 1 of 1
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
    Ask FixBot
  6. Hitachi CP-X440 Power Supply Unit Replacement: step 6, image 1 of 1
    • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
    Ask FixBot
  7. Hitachi CP-X440 Power Supply Unit Replacement: step 7, image 1 of 1
    • Remove the motherboard so the projector is exposed.
    Ask FixBot
  8. Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: step 8, image 1 of 2 Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: step 8, image 2 of 2
    • Remove the silver plastic protective piece from the top of the power supply unit.
    • Remove the black pin holder by using the spudger.
    Ask FixBot
  9. Hitachi CP-X440 Power Supply Unit Replacement: step 9, image 1 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 9, image 2 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 9, image 3 of 3
    • Remove the 10 mm screws that are holding the power supply unit to the projector.
    Ask FixBot
  10. Hitachi CP-X440 Power Supply Unit Replacement: step 10, image 1 of 2 Hitachi CP-X440 Power Supply Unit Replacement: step 10, image 2 of 2
    • Remove the wires that are attached to the projector from the power supply unit.
    Ask FixBot
  11. Hitachi CP-X440 Power Supply Unit Replacement: step 11, image 1 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 11, image 2 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 11, image 3 of 3
    • Remove the black wire by using the Phillips #2 screwdriver to remove the 10 mm screw.
    • Pull on the metal bracket which should come free, and then pull the wire up so it is released.
    Ask FixBot
  12. Hitachi CP-X440 Power Supply Unit Replacement: step 12, image 1 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 12, image 2 of 3 Hitachi CP-X440 Power Supply Unit Replacement: step 12, image 3 of 3
    • Remove the black wire by using the Phillips #2 screwdriver to remove the 10 mm silver screw.
    • Pull on the metal bracket which should come free. Then pull the wire up so it is released.
    • The third picture marks where the base of the second picture's screw is located.
    Ask FixBot
  13. Hitachi CP-X440 Power Supply Unit Replacement: step 13, image 1 of 1
    • Remove the last 10 mm screw to the secondary motherboard using the Phillips #2 screwdriver and the power supply unit will lift free.
    Ask FixBot
noah wright
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 432
