Hitachi CP-X440 Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
54
All Time:
553
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will show you how to disassemble the projector acting as a supplemental guide for the other replacement guides for this device. Many of the parts that may need replacing in the projector require the device to be disassembled.
Before beginning disassembly, be sure the projector is unplugged from any outlets.
Tools
    1. Hitachi CP-X440 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Turn the projector upside down so the bottom is facing up.
      • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
      • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
      Ask FixBot
    2. Hitachi CP-X440 Motherboard Replacement: step 2, image 1 of 2 Hitachi CP-X440 Motherboard Replacement: step 2, image 2 of 2
      • Flip the projector right-side up and navigate to the back panel.
      • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
      • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
      Ask FixBot
    3. Hitachi CP-X440 Motherboard Replacement: step 3, image 1 of 2 Hitachi CP-X440 Motherboard Replacement: step 3, image 2 of 2
      • Now turn the projector so the front is facing you.
      • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
      Ask FixBot
    4. Hitachi CP-X440 Motherboard Replacement: step 4, image 1 of 2 Hitachi CP-X440 Motherboard Replacement: step 4, image 2 of 2
      • Gently remove the cables from their white connectors on the circuit board.
      Ask FixBot
    5. Hitachi CP-X440 Motherboard Replacement: step 5, image 1 of 1
      • Gently pull out the three orange ribbons from their white connectors on the circuit board.
      • You can use a spudger tool to pry them out of place.
      Ask FixBot
    6. Hitachi CP-X440 Motherboard Replacement: step 6, image 1 of 1
      • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
      Ask FixBot
    7. Hitachi CP-X440 Motherboard Replacement: step 7, image 1 of 1
      • Remove the motherboard so the projector is exposed.
      Ask FixBot
Abby Myers
294 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 553
