Hitachi CP-X2011N Motherboard Replacement
  1. Hitachi CP-X2011N Motherboard Replacement, Motherboard: step 1, image 1 of 3 Hitachi CP-X2011N Motherboard Replacement, Motherboard: step 1, image 2 of 3 Hitachi CP-X2011N Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Orient the projector with the underside facing up and remove all nine 11.5 mm screws with a Phillips #00 screwdriver.
    • On the outlet area on the rear of the device, remove all three 11.5 mm screws with a Phillips #00 screwdriver.
    • Carefully remove the cover using your hands.
    Ask FixBot
  2. Hitachi CP-X2011N Motherboard Replacement: step 2, image 1 of 3 Hitachi CP-X2011N Motherboard Replacement: step 2, image 2 of 3 Hitachi CP-X2011N Motherboard Replacement: step 2, image 3 of 3
    • Remove all four 10.47 mm screws holding the motherboard in place with a Phillips #00 screwdriver.
    Ask FixBot
  3. Hitachi CP-X2011N Motherboard Replacement: step 3, image 1 of 3 Hitachi CP-X2011N Motherboard Replacement: step 3, image 2 of 3 Hitachi CP-X2011N Motherboard Replacement: step 3, image 3 of 3
    • Carefully disconnect all seven ribbon cables and wire connections from the motherboard using tweezers.
    Ask FixBot
  4. Hitachi CP-X2011N Motherboard Replacement: step 4, image 1 of 1
    • Carefully remove the motherboard from the projector.
    Ask FixBot
  5. Hitachi CP-X2011N Motherboard Replacement: step 5, image 1 of 3 Hitachi CP-X2011N Motherboard Replacement: step 5, image 2 of 3 Hitachi CP-X2011N Motherboard Replacement: step 5, image 3 of 3
    • Remove all jack standoff screws to detach the ports from the cover using a Phillips #00 screwdriver.
    Ask FixBot
  6. Hitachi CP-X2011N Motherboard Replacement: step 6, image 1 of 1
    • Remove the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Angel Hernandez
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 43
All Time: 179
