Hitachi CP-X2010N Top Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
49
All Time:
411
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The top panel houses and protects the projector's sensitive internal components. If there is any damage to the top case, it may need to be replaced. Removing the top panel is also necessary to replace most of the internal components for the Hitachi CP-X2010N.
Before removing the top panel, ensure the device is powered off and unplugged. Also make sure that the projector has cooled off if it has recently been used as it could become warm after prolonged use.
Tools
    1. Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement, Top Panel: step 1, image 3 of 3
      • Flip the projector upside down to expose the screws on the underside.
      Ask FixBot
    2. Hitachi CP-X2010N Top Panel Replacement: step 2, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 2, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 2, image 3 of 3
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
      Ask FixBot
    3. Hitachi CP-X2010N Top Panel Replacement: step 3, image 1 of 1
      • Flip projector right side up and orient it so you are facing the rear panel.
      Ask FixBot
    4. Hitachi CP-X2010N Top Panel Replacement: step 4, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 4, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
      Ask FixBot
    5. Hitachi CP-X2010N Top Panel Replacement: step 5, image 1 of 3 Hitachi CP-X2010N Top Panel Replacement: step 5, image 2 of 3 Hitachi CP-X2010N Top Panel Replacement: step 5, image 3 of 3
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
      Ask FixBot
3 other people completed this guide.
Chance Kidd
1,184 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 49
All Time: 411
