Hitachi CP-X2010N Lamp Replacement
    1. Hitachi CP-X2010N Lamp Replacement, Top Panel: step 1, image 1 of 3 Hitachi CP-X2010N Lamp Replacement, Top Panel: step 1, image 2 of 3 Hitachi CP-X2010N Lamp Replacement, Top Panel: step 1, image 3 of 3
      • Flip the projector upside down to expose the screws on the underside.
      Ask FixBot
    2. Hitachi CP-X2010N Lamp Replacement: step 2, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 2, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 2, image 3 of 3
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
      Ask FixBot
    3. Hitachi CP-X2010N Lamp Replacement: step 3, image 1 of 1
      • Flip projector right side up and orient it so you are facing the rear panel.
      Ask FixBot
    4. Hitachi CP-X2010N Lamp Replacement: step 4, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 4, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
      Ask FixBot
    5. Hitachi CP-X2010N Lamp Replacement: step 5, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 5, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 5, image 3 of 3
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
      Ask FixBot
    1. Hitachi CP-X2010N Lamp Replacement, Motherboard: step 6, image 1 of 3 Hitachi CP-X2010N Lamp Replacement, Motherboard: step 6, image 2 of 3 Hitachi CP-X2010N Lamp Replacement, Motherboard: step 6, image 3 of 3
      • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
      • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
      Ask FixBot
    2. Hitachi CP-X2010N Lamp Replacement: step 7, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 7, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 7, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
      • Move the wires for better access to the screws if needed.
      Ask FixBot
    3. Hitachi CP-X2010N Lamp Replacement: step 8, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 8, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 8, image 3 of 3
      • Remove the bracket that was being held by the screw.
      • Take a picture or memorize its orientation for easier reinstallation.
      Ask FixBot
    4. Hitachi CP-X2010N Lamp Replacement: step 9, image 1 of 2 Hitachi CP-X2010N Lamp Replacement: step 9, image 2 of 2
      • Pull the button array and network adapter out carefully.
      • Make sure all the wires connected to the array are unplugged.
      Ask FixBot
    5. Hitachi CP-X2010N Lamp Replacement: step 10, image 1 of 2 Hitachi CP-X2010N Lamp Replacement: step 10, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
      • Keep the screw and washer in an easily accessible place.
      Ask FixBot
    6. Hitachi CP-X2010N Lamp Replacement: step 11, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
      Ask FixBot
    7. Hitachi CP-X2010N Lamp Replacement: step 12, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 12, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 12, image 3 of 3
      • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
      Ask FixBot
    8. Hitachi CP-X2010N Lamp Replacement: step 13, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 13, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 13, image 3 of 3
      • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
      • Too much force could break the ribbon cable.
      Ask FixBot
    9. Hitachi CP-X2010N Lamp Replacement: step 14, image 1 of 2 Hitachi CP-X2010N Lamp Replacement: step 14, image 2 of 2
      • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
      Ask FixBot
    1. Hitachi CP-X2010N Lamp Replacement, Lamp: step 15, image 1 of 2 Hitachi CP-X2010N Lamp Replacement, Lamp: step 15, image 2 of 2
      • Using a Phillips #2 screwdriver, loosen three silver captive screws from lamp housing.
      • The screws are captive and do not need to be removed from the housing.
      Ask FixBot
    2. Hitachi CP-X2010N Lamp Replacement: step 16, image 1 of 2 Hitachi CP-X2010N Lamp Replacement: step 16, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the black 12 mm screw holding the housing to the lamp's brown power connector.
      Ask FixBot
    3. Hitachi CP-X2010N Lamp Replacement: step 17, image 1 of 3 Hitachi CP-X2010N Lamp Replacement: step 17, image 2 of 3 Hitachi CP-X2010N Lamp Replacement: step 17, image 3 of 3
      • Remove the lamp from its housing.
      • You may need to use an iFixit opening tool to loosen the brown power cord from its connector.
      Ask FixBot
    4. Hitachi CP-X2010N Lamp Replacement: step 18, image 1 of 2 Hitachi CP-X2010N Lamp Replacement: step 18, image 2 of 2
      • Inspect the lamp for debris or damage.
      • Clean or replace the lamp as needed.
      Ask FixBot
4 other people completed this guide.
Chance Kidd
1,184 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 389
