Introduction
After extended use, the charging port may be worn down. If the device will not power on after charging, the charging port may be defective.
Remove the back cover of the device using a combination of both plastic opening tools.
Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
2 other people completed this guide.
