Hisense Chromebook C11 Hard Drive Replacement
  1. Hisense Chromebook C11 Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
    Ask FixBot
  2. Hisense Chromebook C11 Hard Drive Replacement: step 2, image 1 of 1
    • Unscrew the screws with the Phillips #00 screwdriver.
    Ask FixBot
  3. Hisense Chromebook C11 Hard Drive Replacement: step 3, image 1 of 1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
    Ask FixBot
  4. Hisense Chromebook C11 Hard Drive Replacement, Battery: step 4, image 1 of 1
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
    Ask FixBot
  5. Hisense Chromebook C11 Hard Drive Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to unplug the battery.
    Ask FixBot
  6. Hisense Chromebook C11 Hard Drive Replacement: step 6, image 1 of 1
    • Remove the battery.
    Ask FixBot
  7. Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
    • Unscrew all of the screws that you can access on the hard drive.
    • If you cannot reach the screw beneath the black strip, move on to the next step.
    Ask FixBot
  8. Hisense Chromebook C11 Hard Drive Replacement: step 8, image 1 of 3 Hisense Chromebook C11 Hard Drive Replacement: step 8, image 2 of 3 Hisense Chromebook C11 Hard Drive Replacement: step 8, image 3 of 3
    Buy
    • Remove the black strip using the tweezers.
    Ask FixBot
  9. Hisense Chromebook C11 Hard Drive Replacement: step 9, image 1 of 1
    • Unscrew the screw beneath the black strip if you haven't done so already.
    Ask FixBot
  10. Hisense Chromebook C11 Hard Drive Replacement: step 10, image 1 of 2 Hisense Chromebook C11 Hard Drive Replacement: step 10, image 2 of 2
    • Remove the ribbon with the tweezers.
    Ask FixBot
  11. Hisense Chromebook C11 Hard Drive Replacement: step 11, image 1 of 2 Hisense Chromebook C11 Hard Drive Replacement: step 11, image 2 of 2
    • Using the tweezers, carefully remove the latches attaching the silver computer chip.
    Ask FixBot
  12. Hisense Chromebook C11 Hard Drive Replacement: step 12, image 1 of 2 Hisense Chromebook C11 Hard Drive Replacement: step 12, image 2 of 2
    • Continue gently removing all remaining points of attachment.
    Ask FixBot
  13. Hisense Chromebook C11 Hard Drive Replacement: step 13, image 1 of 1
    • Carefully remove the hard drive.
    Ask FixBot
Chelsea Charles
425 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 38
All Time: 1,466
