Hisense Chromebook C11 Battery Replacement
    1. Hisense Chromebook C11 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Remove the front two hub caps.
      • When finished, you should be able to remove the back cover.
      Ask FixBot
    2. Hisense Chromebook C11 Battery Replacement: step 2, image 1 of 1
      • Unscrew the screws with the Phillips #00 screwdriver.
      Ask FixBot
    3. Hisense Chromebook C11 Battery Replacement: step 3, image 1 of 1
      • Pry the perimeter of the case open with the plastic opening tool.
      • Remove the back panel.
      Ask FixBot
    1. Hisense Chromebook C11 Battery Replacement, Battery: step 4, image 1 of 1
      • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
      • Unscrew the screws with the Phillips #000 screwdriver.
      Ask FixBot
    2. Hisense Chromebook C11 Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to unplug the battery.
      Ask FixBot
    3. Hisense Chromebook C11 Battery Replacement: step 6, image 1 of 1
      • Remove the battery.
      Ask FixBot
4 other people completed this guide.
Alexander Burrell
457 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 Members
60 Guides authored
4 Guide Comments
Thank you! Andrew Beiler IBM Research New York
andybeilerny - Reply Share
Hola mi chome prende pero aparece un recuadro que dice error no esta instalado el chrome os
fidellopez5583 - Reply Share
Cuanto cuesta la bateria estoy dispuesto a pagar 20 dlls por ella si es nesesario
Marco Antonio Ramírez López - Reply Share
আমাদের একটি পুরানো গল্প আছে কিভাবে এখন ঠিক করব
mdjoirana45 - Reply Share
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 29
All Time: 3,980
