Hipstreet Titan Plus Screen Replacement
    1. Hipstreet Titan Plus Screen Replacement, Screen: step 1, image 1 of 2 Hipstreet Titan Plus Screen Replacement, Screen: step 1, image 2 of 2
      • Use the iFixit opening tools to pry the screen from the back casing of the device.
      • Now that the screen and back casing have been separated, lay them flat on the table with the inside facing up.
      Ask FixBot
    2. Hipstreet Titan Plus Screen Replacement: step 2, image 1 of 1
      • Use the spudger tool to remove the speaker from back casing of the device.
      Ask FixBot
    3. Hipstreet Titan Plus Screen Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to remove the black adhesive strips covering the wires.
      • After, set the strips aside. You will use them later.
      Ask FixBot
    4. Hipstreet Titan Plus Screen Replacement: step 4, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 4, image 2 of 2
      • Use the spudger to release the three black clips.
      • Ensure to remove the main far right clip, which connects the screen to the motherboard.
      Ask FixBot
    5. Hipstreet Titan Plus Screen Replacement: step 5, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 5, image 2 of 2
      • Remove the three screws from the bottom of the motherboard.
      Ask FixBot
    6. Hipstreet Titan Plus Screen Replacement: step 6, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 6, image 2 of 2
      • Use a spudger to gently remove the battery from the motherboard.
      Ask FixBot
    7. Hipstreet Titan Plus Screen Replacement: step 7, image 1 of 1
      • All components will be removable from the screen after the battery, motherboard and all the black clips have been undone.
      Ask FixBot
    8. Hipstreet Titan Plus Screen Replacement: step 8, image 1 of 2 Hipstreet Titan Plus Screen Replacement: step 8, image 2 of 2
      • Use the spudger to push back the clips along the side of the device and remove the screen.
      Ask FixBot
2 other people completed this guide.
Kari Cannon
500 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Miles Fall 2015 Member of UMass Dartmouth, Team 1-1, Miles Fall 2015
UMASSD-MILES-F15S1G1
3 Members
60 Guides authored
1 Guide Comment
How can I find a replacement screen
Moe Nergaard - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 89
All Time: 939
