Hipstreet Titan 2 HD Screen Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
101
All Time:
3,629
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will allow users to replace the screen components on the tablet. This is a moderately simple process. Users will need a replacement screen to complete the process.
Tools
    1. Hipstreet Titan 2 HD Screen Replacement, Rear Case: step 1, image 1 of 1
      • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
      • The screws are located on the bottom face of the device, near the power and volume controls.
      Ask FixBot
    2. Hipstreet Titan 2 HD Screen Replacement: step 2, image 1 of 1
      • Place the small suction cup on your screen.
      • Moisturize the bottom of the suction cup to ensure a proper seal.
      • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
      Ask FixBot
    3. Hipstreet Titan 2 HD Screen Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
      • Grasp the small suction cup.
      Ask FixBot
    4. Hipstreet Titan 2 HD Screen Replacement: step 4, image 1 of 2 Hipstreet Titan 2 HD Screen Replacement: step 4, image 2 of 2
      • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
      • Pull upward on the small suction cup handle while sliding the opening tool.
      • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
      Ask FixBot
    5. Hipstreet Titan 2 HD Screen Replacement: step 5, image 1 of 2 Hipstreet Titan 2 HD Screen Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to remove the speaker from the rear cover.
      • The speaker is held in place with adhesive and is easily removed.
      • Do not pull on the speaker wires. This could damage the soldering connections.
      Ask FixBot
    6. Hipstreet Titan 2 HD Screen Replacement: step 6, image 1 of 1
      • Once the speaker is disconnected, the cover removal is complete.
      Ask FixBot
    1. Hipstreet Titan 2 HD Screen Replacement, Screen: step 7, image 1 of 3 Hipstreet Titan 2 HD Screen Replacement, Screen: step 7, image 2 of 3 Hipstreet Titan 2 HD Screen Replacement, Screen: step 7, image 3 of 3
      • Lift the hinges on the three ribbon connector clips and disconnect the ribbon connector.
      Ask FixBot
    2. Hipstreet Titan 2 HD Screen Replacement: step 8, image 1 of 1
      • Using the PH#00 screwdriver, remove the three 0.145 inch circuit board screws.
      Ask FixBot
    3. Hipstreet Titan 2 HD Screen Replacement: step 9, image 1 of 1
      • Remove battery, speaker and circuit board from screen.
      • Gently move circuit board assembly with speaker and battery away from device to ensure you do not damage the solder connections.
      Ask FixBot
    4. Hipstreet Titan 2 HD Screen Replacement: step 10, image 1 of 2 Hipstreet Titan 2 HD Screen Replacement: step 10, image 2 of 2
      • Use plastic opening tools to remove screen from front cover.
      • The screen is held in with plastic tabs.
      • Use of too much force on the screen may result in unwanted damage to screen.
      • To avoid damage to screen, ensure the metal screen cover does not catch on the plastic tabs.
      Ask FixBot
    5. Hipstreet Titan 2 HD Screen Replacement: step 11, image 1 of 1
      • Remove screen solder connector with solder removal tool.
      • Solder new screen wire to circuit board with soldering tool.
      Ask FixBot
5 other people completed this guide.
Jeffrey
766 Reputation
5 Guides authored
2 Guide Comments
Your step 11 is irrelevant since this look like it is the wifi antenna.
The other end of this wire is not connected to the screen. I suggested removing gently the other end from the casing (it's held with adhesive) and so, no soldering at all to do.
Otherwise, great guide! Thanks!
kamen99 - Reply Share
OK, so I cracked my screen and I cracked it today so I went on there to do the usual, you know? Well when I turned it on, my password lock started bugging out! (I thought a was being hacked) I am worried to do this (Step - Step thing) because I am just a child (NOT A SMALL ONE DON'T REALLY WORRY!) and my parents will be disappointed in me, I got this for my birthday! But this one is a white HipStreet tablet, one of those fancy new ones, I checked it out to see if it was actually a crack so I took off my screen protector and I felt it, but no, no! It was a crack but I couldn't feel it! I thought it was REALLY in the tablet, like through the hard-drive and wires and stuff like that, please help me I don't want to get in trouble, I can't really afford another one, and my parents say "You better protect this with your entire life, because if you break this one..YOU WON'T GET ANOTHER!" (I had 2 tablets along time ago, I broke them both, OH PLEASE I WAS A SMALL CHILD!) So please help me, Thank - You!
N3rD Al3rT - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 101
All Time: 3,629
