Hipstreet Equinox 2 Screen Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
85
All Time:
1,299
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Often times the screen gets little dots that wont go away, or it could be cracked from dropping the tablet. The hardest part about replacing the screen is taking everything else off to get to it.
Tools
    1. Hipstreet Equinox 2 Screen Replacement, Rear Case: step 1, image 1 of 1
      • Remove the two 3mm screws using a PH00 screwdriver.
      Ask FixBot
    2. Hipstreet Equinox 2 Screen Replacement: step 2, image 1 of 1
      • Use the blue plastic opening tool to gently pry the back case off.
      Ask FixBot
    1. Hipstreet Equinox 2 Screen Replacement, Battery: step 3, image 1 of 1
      • Disconnect the wires that connect the battery to the motherboard using the spudger.
      Ask FixBot
    2. Hipstreet Equinox 2 Screen Replacement: step 4, image 1 of 1
      • Slide the spudger underneath the battery and gently lift it off of the adhesive.
      Ask FixBot
    3. Hipstreet Equinox 2 Screen Replacement: step 5, image 1 of 2 Hipstreet Equinox 2 Screen Replacement: step 5, image 2 of 2
      • Place the new battery in the same location and connect the wires the same way as the previous battery.
      Ask FixBot
    1. Hipstreet Equinox 2 Screen Replacement, Motherboard: step 6, image 1 of 1
      • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
      Ask FixBot
    2. Hipstreet Equinox 2 Screen Replacement: step 7, image 1 of 1
      • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
      Ask FixBot
    3. Hipstreet Equinox 2 Screen Replacement: step 8, image 1 of 1
      • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
      Ask FixBot
    4. Hipstreet Equinox 2 Screen Replacement: step 9, image 1 of 1
      • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
      Ask FixBot
    1. Hipstreet Equinox 2 Screen Replacement, Screen: step 10, image 1 of 1
      • Remove these 2.5mm screws and brackets holding the screen down using a PH00 screwdriver.
      Ask FixBot
    2. Hipstreet Equinox 2 Screen Replacement: step 11, image 1 of 1
      • Gently lift the screen out of the tablet
      Ask FixBot
Brandon Snodgrass
410 Reputation
4 Guides authored
Clemson, Team 15-8, Shirley Winter 2015 Member of Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Members
72 Guides authored
1 Guide Comment
OK, so I cracked my screen and I cracked it today so I went on there to do the usual, you know? Well when I turned it on, my password lock started bugging out! (I thought a was being hacked) I am worried to do this (Step - Step thing) because I am just a child (NOT A SMALL ONE DON'T REALLY WORRY!) and my parents will be disappointed in me, I got this for my birthday! But this one is a white HipStreet tablet, one of those fancy new ones, I checked it out to see if it was actually a crack so I took off my screen protector and I felt it, but no, no! It was a crack but I couldn't feel it! I thought it was REALLY in the tablet, like through the hard-drive and wires and stuff like that, please help me I don't want to get in trouble, I can't really afford another one, and my parents say "You better protect this with your entire life, because if you break this one..YOU WON'T GET ANOTHER!" (I had 2 tablets along time ago, I broke them both, OH PLEASE I WAS A SMALL CHILD!) So please help me, Thank - You!
N3rD Al3rT - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 85
All Time: 1,299
