Up to 20% off select tools
Hilti DWP 10 Troubleshooting
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
102
All Time:
102
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide helps pinpoint the cause of the tank not building or maintaining air pressure. It should be applicable to other portable water supply products.
      • Depress and twist the pump handle to lock it into the retainer where it enters the tank.
      • Rotate the locked handle counterclockwise to unscrew the pump cylinder from the tank.
      Ask FixBot
      • Release the pump handle from its retainer and try a few quick strokes of the piston. If there's noticeable air flow at the opposite end of the cylinder, move to the next step.
      • Remove the two Pozidriv 2 screws holding the pump handle retainer onto the cylinder and remove the retainer and piston from the cylinder.
      • If the cup-shaped diaphragm on the end of the piston rod is visibly worn, loose in the cylinder, or hardened, replace it.
      • The diaphragm part is modeled for 3D printing here.
      Ask FixBot
      • Wrap a balloon or sheet of strong plastic tightly around the output end of the cylinder and pump the handle.
      • The balloon should inflate. If it maintains pressure after the pump piston is drawn back, move to the next step.
      • Inspect the rubber plug that acts as a check valve on the far end of the cylinder. The plug or cylinder surface may need to be cleaned in order for the two to make good contact.
      • If the plug and cylinder surface looked good, consider remounting the plug through a washer placed inside the cylinder at the bottom. This sets the plug further into the pump cylinder, increasing the sealing force.
      Ask FixBot
      • If no previous step addressed the problem, use an external pump or compressor to pressurize the tank through the water hose.
      • Listen or feel for air flow to locate the leak. Possible culprits are hose fittings and the O-ring between the pump cylinder and the mouth of the tank.
      Ask FixBot
Finish Line
Jakob C
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 102
All Time: 102
