HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement
Views: 8.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
63
Past 30 Days:
232
All Time:
8,935
Comments: 25
5 comments on steps, 20 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
    1. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove 3 PH1 screws: step 1, image 1 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove 3 PH1 screws: step 1, image 2 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove 3 PH1 screws: step 1, image 3 of 3
      • Ensure your puck is not fully charged. Preferably, do this when your puck is discharged and your smart bottle ask you for recharge
      • Unscrew Bluetooth Sensor Puck from your bottle (obviously)
      • Remove three Philips 1 screws and place them somewhere where you will not accidentally loose.
      • You will have to put a bit of a force to remove those screws, rotate your screwdriver counterclockwise. When done, all screws will fall out of a puck, when you rotate it upside down and give a bit of shake.
      • You might want to use your thumb when shaking those screws out of your puck to avoid premature separation of its lid in process
      Ask FixBot
    2. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Disconnect the battery of a puck: step 2, image 1 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Disconnect the battery of a puck: step 2, image 2 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Disconnect the battery of a puck: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Now, when you've removed those screws, you can easily pop the lid of your puck
      • There are no latches nor adhesive to hold the lid.
      • The battery is located on the lid, but the cable is long enough for you to open a puck safely without breaking them.
      • The battery cable itself has a small white connector.
      • Disconnect battery cable by holding a puck (side with motherboard) in one hand and pulling white connector using the other hand. No tweezers necessary here, use your fingernails and grab the upper part of a connector, which has small bumps on both left and right side for that purpose.
      • Do not pull that connector by red and black cables, you may break those
      • If you can't pull out the battery connector, try doing so again by adding a small left-right shake of your hand when pulling up. This will connector's grip a bit.
      • Be careful not to bend small pogo-pins in process, those are responsible for delivery power from external magnetic connector to the board, so you could charge the device
      Ask FixBot
    3. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove battery itself from the lid: step 3, image 1 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove battery itself from the lid: step 3, image 2 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Remove battery itself from the lid: step 3, image 3 of 3
      • The battery is held in place by one piece of double-sided tape and has a cardboard piece attached to its top in a same way, probably for additional insulation
      • Use something plastic to remove the battery, or cut the adhesive using dental floss.
      • Be careful not to puncture the battery
      • Battery inside consists of two lithium-ion 3.7v batteries taped together. Overall capacity is 420 mAh or 1.55 Wh, and size is around 10x12x30mm
      • The battery compartment is slightly bigger than the battery itself, so you may use a new battery of slightly bigger dimensions.
      Ask FixBot
    4. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, Replace an old battery with a new one: step 4, image 1 of 1
      • I haven't seen any battery with this connector available, so you will have to do a bit of soldering
      • Mind the polarity of battery connector. Note that the red wire should be on outer side of the puck, while the black one in the inner side.
      • Messing with polarity may force you to replace this puck entierly and the new one costs 48$
      • After you connect a new battery, your puck will flash a few times, this is expected
      • You will have to recalibrate the sensor puck after full reassembly. In fact, the application on your phone will remind you of this.
      Ask FixBot
    5. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, About an original battery: step 5, image 1 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, About an original battery: step 5, image 2 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, About an original battery: step 5, image 3 of 3
      • An original 3.7V battery consists of two batteries stitched together in parallel and a protection board
      • Protection board itself has two chips:
      • 8205A — a Dual N-Channel MOSFET
      • DW01A — a "lifetime" battery protection IC (over-charge, over-discharge, over-current). Funny, the datasheet on this states that it is designed for a single cell, but we do see that here it is connected to two of them. I presume this has implications on a life time in the long run.
      • The battery leads are not welded, they're soldered — so you can detach the BMS board from cells easily by clipping out the leads first, to avoid any possibility of short-circuit, heating those leftovers a bit and pushing them to side. Thus you wll have a clean spot to solder a new battery leads to.
      Ask FixBot
    6. HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, A replacement battery is hard to find: step 6, image 1 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, A replacement battery is hard to find: step 6, image 2 of 3 HidrateSpark PRO LED Bluetooth Sensor Puck Rechargeable Battery Replacement, A replacement battery is hard to find: step 6, image 3 of 3
      • I was not able to find the exact match by size and capacity
      • Any 3.7V Li-Ion/Li-Pol battery you can fit will work.
      • You can use a few smaller batteries like the original did.
      • You can use a smaller battery, or a bigger battery like I did
      • Use a replacement battery only if it has a protection board. I have no idea if a puck PCB has any kind of protection circuit built in. Better safe than sorry.
      • I ended up using a rechargeable 3.7V battery from a disposable vape (Elfbar 800).
      • This battery did not fit the puck case without modification, thus, I had to remove some plastics that held the original battery in place
      Ask FixBot
5 other people completed this guide.
Roman Suvorov
288 Reputation
1 Guide authored
20 Guide Comments
Hello, I have not been able to find a replacement battery for my puck. I have checked online and was able to find some, but required purchasing a quantity of 500 to 1000 pieces.
If you have any info that would help me in this matter it would be greatly appreciated.
Thank you
Mark LaRosa - Reply Share
The HidrateSpark actually uses two smaller batteries stitched together via a small circuit with overcharge protection.
So one can either do the same or find a similarly sized battery.
Technically, any 3.7v lithium-ion/polymer battery should work.
I myself have used a battery from a small Elfbar 800 (single-use vape). All of those contain a rechargeable LiPol battery.
We do recycle those in Ukraine to make power banks for the army.
This battery almost fits in a puck, but since it is a bit longer, I have had to cut a bit of plastic which held an original rectangular battery.
However, since I have not disassembled my pack completely, I am not sure that the PCB of the puck itself has any kind of overcharge protection. So this might be not a good idea to connect a new battery without ensuring either the puck or battery has overcharge protection.
Roman Suvorov - Reply Share
Why couldn't you solder the protection circuit to the battery you replaced the old one with?
My bf gave me one of these bottles but without a charger. I realized my old Pebble watch charger fit perfectly & tried charging the puck with it but it didn't do anything.
The battery reads 0.00v with multimeter. Since you said the battery has over discharge protection, that likely means the battery needs replacing huh?
Heather Hodge - Reply Share
Well, I am no battery expert, so I advise you to ask someone else to be sure.
Though I can say I remember there was a method of reviving batteries by de-soldering them from BMS and charging those "manually" with lover voltage for some time, to gradually restore its internal chemisty and bring back to life.
You don't have to charge battery, really, just give it some boost for BMS to work.
This will gift you some additional time and contribute to waste reducing, however, once the degradation process started, it will only accelerate.
Did you check the voltage output from BMS or directly from battery leads?
BMS giving out 0V is expected, since it cuts out battery before it dies.
Should still charge though. Did not in my case, when my battery have died.
Anyway, I did not solder the protection circuit simply because I had no soldering iron at that time.
I will get one soon, so I might try putting the BMS back and publishing the results here, after some testing.
I'm just now seeing your response. It's actually been awhile since I tested the battery voltage, so I'm not sure where I placed the leads to measure voltage. Thanks for replying cuz I hadn't considered the BMS possibly causing the voltage appear to be 0.
I'm no battery expert either, but I was under the impression lipo batteries cannot be allowed to discharge completely or they can't be revived. I did know the older chemistry rechargeable batteries could be revived. Can't think of what they're called right now.
Thx again for taking the time to respond. Ill check back into my battery when I've got some time & see whether its actually dead or not and try reviving it if so.
Awesome of you to post this DIY. There's hardly any info online regarding the batteries in this bottle.
Past 24 Hours: 4
Past 7 Days: 63
Past 30 Days: 232
All Time: 8,935
