Heyday Suitcase Turntable Platter Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
63
All Time:
799
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide if you need to replace the platter of your Heyday Suitcase Turntable. The platter is where you place the record or vinyl and holds it in place. If the platter is damaged or not placed correctly, it will affect the sound quality.
Before beginning this guide, turn off the record player and disconnect the power cord.
Tools
    1. Heyday Suitcase Turntable Platter Replacement, Platter: step 1, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Unlock the front latches and open the turntable suitcase cover.
      • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
      • Be careful, as the spindle shaft may fly off in an unexpected direction.
      Ask FixBot
    2. Heyday Suitcase Turntable Platter Replacement: step 2, image 1 of 1
      • Use both hands to gently lift the platter up and off of the turntable.
      Ask FixBot
Once you have removed the platter, you can replace the platter. Once you have replaced the platter, press the spindle shaft back into place.
Faith Adelabu
85 Reputation
1 Guide authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 63
All Time: 799
