Heyday Suitcase Turntable Needle Replacement
    1. Heyday Suitcase Turntable Needle Replacement, Needle: step 1, image 1 of 2 Heyday Suitcase Turntable Needle Replacement, Needle: step 1, image 2 of 2
      • Before you begin the repair, turn off the record player and unplug the power cord.
      • Remove cartridge lock by pushing inwards (towards the needle arm, while lightly squeezing the sides by hand. Then pull downwards and towards you to disengage the locking hook. This will unhook the lock between cartridge and base.
      Ask FixBot
    2. Heyday Suitcase Turntable Needle Replacement: step 2, image 1 of 1
      • Disconnect the wires from the cartridge.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Replace the needle by clipping it back onto the cartridge and then reconnect the wires to the correct part of the cartridge.
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 42
All Time: 1,223
