Heyday Suitcase Turntable Motor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
66
All Time:
821
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 50 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If you need to replace the motor of your Heyday Suitcase Turntable, follow this guide.
If the turntable does not spin when the device is on and has power, it may be because the motor is damaged or faulty and needs to be replaced.
Before beginning this repair, be sure turn the device off and unplugged from the power cord.
Tools
    1. Heyday Suitcase Turntable Motor Replacement, Platter: step 1, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Unlock the front latches and open the turntable suitcase cover.
      • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
      • Be careful, as the spindle shaft may fly off in an unexpected direction.
      Ask FixBot
    2. Heyday Suitcase Turntable Motor Replacement: step 2, image 1 of 1
      • Use both hands to gently lift the platter up and off of the turntable.
      Ask FixBot
    1. Heyday Suitcase Turntable Motor Replacement, Baseboard: step 3, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
      Ask FixBot
    2. Heyday Suitcase Turntable Motor Replacement: step 4, image 1 of 1
      • Use a metal spudger to pry the baseboard off of the case.
      • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
      Ask FixBot
    3. Heyday Suitcase Turntable Motor Replacement: step 5, image 1 of 2 Heyday Suitcase Turntable Motor Replacement: step 5, image 2 of 2
      • Disconnect the cords from the circuit board.
      • Take a picture beforehand so it's easier to put them back during reassembly.
      • Remove the baseboard.
      Ask FixBot
    1. Heyday Suitcase Turntable Motor Replacement, Motor: step 6, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
      • The motor is located underneath the platter.
      Ask FixBot
    2. Heyday Suitcase Turntable Motor Replacement: step 7, image 1 of 1
      • Flip the baseboard over.
      • Unplug the cable connecting the motor to the baseboard.
      • Remove the motor.
      Ask FixBot
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 66
All Time: 821
