Heyday Suitcase Turntable Lever Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
59
All Time:
435
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Follow this repair guide if you need to replace the lever of your Heyday Suitcase Turntable.
If the tonearm does not raise or lower, the lever likely needs to be replaced.
Before beginning this repair, turn off the record player and unplug the power cord.
Tools
    1. Heyday Suitcase Turntable Lever Replacement, Baseboard: step 1, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
      Ask FixBot
    2. Heyday Suitcase Turntable Lever Replacement: step 2, image 1 of 1
      • Use a metal spudger to pry the baseboard off of the case.
      • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
      Ask FixBot
    3. Heyday Suitcase Turntable Lever Replacement: step 3, image 1 of 2 Heyday Suitcase Turntable Lever Replacement: step 3, image 2 of 2
      • Disconnect the cords from the circuit board.
      • Take a picture beforehand so it's easier to put them back during reassembly.
      • Remove the baseboard.
      Ask FixBot
    1. Heyday Suitcase Turntable Lever Replacement, Lever: step 4, image 1 of 2 Heyday Suitcase Turntable Lever Replacement, Lever: step 4, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the screw securing the plate that covers the lever.
      • Remove the plate blocking access to the lever.
      Ask FixBot
    2. Heyday Suitcase Turntable Lever Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the plate securing the lever.
      Ask FixBot
    3. Heyday Suitcase Turntable Lever Replacement: step 6, image 1 of 1
      • Pull the lever out of the front of the device.
      Ask FixBot
Caroline D'Amato
565 Reputation
6 Guides authored
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 59
All Time: 435
