Helm Khuraburi Watch Adjustment and Sizing Guide
  1. Helm Khuraburi Watch Adjustment and Sizing Guide, Removal of Bracelet: step 1, image 1 of 2 Helm Khuraburi Watch Adjustment and Sizing Guide, Removal of Bracelet: step 1, image 2 of 2
    • Use a small screwdriver to remove the screws on one side of the bracelet (there are several screws, choose the most accessible). This will open the watch bracelet.
    Ask FixBot
  2. Helm Khuraburi Watch Adjustment and Sizing Guide, Removing the Spring Bar from the Watch Case: step 2, image 1 of 2 Helm Khuraburi Watch Adjustment and Sizing Guide, Removing the Spring Bar from the Watch Case: step 2, image 2 of 2
    • While applying constant tension in an outward direction, with a spring bar tool, carefully release the spring bar from its retaining hole in the watch case.
    Ask FixBot
  3. Helm Khuraburi Watch Adjustment and Sizing Guide, Detaching the Bracelet from the Watch Case: step 3, image 1 of 1
    • Continuing to apply constant tension, remove the spring bar from its retaining hole in the watch case on the other side. This will release the bracelet from the case, allowing us to access the links we need to add or remove more easily.
    Ask FixBot
  4. Helm Khuraburi Watch Adjustment and Sizing Guide, Adjusting the Bracelet by Removing Links: step 4, image 1 of 2 Helm Khuraburi Watch Adjustment and Sizing Guide, Adjusting the Bracelet by Removing Links: step 4, image 2 of 2
    • With the bracelet removed from the case, unscrew any link that you wish to remove.
    Ask FixBot
  5. Helm Khuraburi Watch Adjustment and Sizing Guide, Adding a Link to the Bracelet: step 5, image 1 of 2 Helm Khuraburi Watch Adjustment and Sizing Guide, Adding a Link to the Bracelet: step 5, image 2 of 2
    • If adding a link, align it with the bracelet, insert the screw, and secure it by screwing it in place.
    Ask FixBot
  6. Helm Khuraburi Watch Adjustment and Sizing Guide, Reassembling the Bracelet Links: step 6, image 1 of 3 Helm Khuraburi Watch Adjustment and Sizing Guide, Reassembling the Bracelet Links: step 6, image 2 of 3 Helm Khuraburi Watch Adjustment and Sizing Guide, Reassembling the Bracelet Links: step 6, image 3 of 3
    • Reattach the links by inserting screws into the holes, ensuring each screw is tight and the links are secure.
    Ask FixBot
  7. Helm Khuraburi Watch Adjustment and Sizing Guide, Reattaching the Bracelet to the Watch Case: step 7, image 1 of 1
    • To reattach the bracelet to the watch case, thread the spring bar through the bracelet and case link.
    Ask FixBot
  8. Helm Khuraburi Watch Adjustment and Sizing Guide, Securing the Bracelet to the Watch Case: step 8, image 1 of 2 Helm Khuraburi Watch Adjustment and Sizing Guide, Securing the Bracelet to the Watch Case: step 8, image 2 of 2
    • Carefully place this assembly on the underside of the watch case. Apply tension to the springbar using the spring bar tool, and move the spring bar inside the case opening.
    Ask FixBot
  9. Helm Khuraburi Watch Adjustment and Sizing Guide, Ensuring the Spring Bar Locks into Place: step 9, image 1 of 1
    • Move the assembly around inside the case opening until you feel the spring bar slot into its retaining hole in the case.
    Ask FixBot
    • Repeat step 7 for the other side of the bracelet.
    Ask FixBot
  10. Helm Khuraburi Watch Adjustment and Sizing Guide, Fine-Tuning the Clasp Position: step 11, image 1 of 3 Helm Khuraburi Watch Adjustment and Sizing Guide, Fine-Tuning the Clasp Position: step 11, image 2 of 3 Helm Khuraburi Watch Adjustment and Sizing Guide, Fine-Tuning the Clasp Position: step 11, image 3 of 3
    • If further smaller adjustments are needed, adjust the clasp mechanism. Use a pen to depress the spring bar holding the clasp in place while applying pressure towards the desired direction.
    Ask FixBot
  11. Helm Khuraburi Watch Adjustment and Sizing Guide, nserting the Clasp into the Springbar Mechanism: step 12, image 1 of 1
    • Depress the other side of the spring bar so that the clasp slides into and is even within the mechanism.
    Ask FixBot
  12. Helm Khuraburi Watch Adjustment and Sizing Guide, Ensuring the Watch Fits Securely and Comfortably: step 13, image 1 of 1
    • Lastly, Ensure a good fit, such that the watch doesn’t move too much and also doesn’t constrict the movement of the user.
    Ask FixBot
Brianna Greene
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 43
All Time: 291
