Up to 20% off select tools
Heel Tip Replacement
Views: 101K
View statistics:
Past 24 Hours:
13
Past 7 Days:
124
Past 30 Days:
721
All Time:
101,421
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Are your heel tips worn down or missing? Walking on metal tips, or uneven worn down rubber tips can be extremely frustrating. With extensive wear, heel tips will naturally deteriorate. It is recommended that they are replaced before the inner tip begins to protrude. This is also important because having an unstable heel can lead to balancing issues.
If you or someone you know have worn down or missing heel tips, you can use this guide to learn how to simply replace your old heel tips with new tips. Why pay a shoe repair shop to replace heel tips, when you can do it yourself and save time and money.
    1. Heel Tip Replacement, Heel Tip: step 1, image 1 of 1
      • Measure the size of your heel tips to know what size to purchase.
      • Most sizes are in the range of 8-13 mm. The variety packs are handy, especially if you have a few pairs to fix.
      • The size pictured in this fix is a 12mm heel tip on a size 9 heel.
      Ask FixBot
    2. Heel Tip Replacement: step 2, image 1 of 1
      • Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
      Ask FixBot
    3. Heel Tip Replacement: step 3, image 1 of 2 Heel Tip Replacement: step 3, image 2 of 2
      • Carefully remove the heel tip with the pliers by twisting and pulling it out. Most can be turned counter clockwise to remove. Be careful not to pull only the rubber off.
      Ask FixBot
    4. Heel Tip Replacement: step 4, image 1 of 2 Heel Tip Replacement: step 4, image 2 of 2
      • Clean the newly exposed tip of any debris.
      Ask FixBot
    5. Heel Tip Replacement: step 5, image 1 of 1
      • Place the pin end of the new tip into the heels opening.
      Ask FixBot
    6. Heel Tip Replacement: step 6, image 1 of 2 Heel Tip Replacement: step 6, image 2 of 2
      • Gently tap the new tip in with the hammer. Careful not to damage the shoes material.
      Ask FixBot
    7. Heel Tip Replacement: step 7, image 1 of 2 Heel Tip Replacement: step 7, image 2 of 2
      • Adjust the tip with the pliers to align the heel tip.
      Ask FixBot
15 other people completed this guide.
Author
with
Stephanie Shipman
533 Reputation
1 Guide authored
2 Guide Comments
What if the replacement pins are too small for original pin hole in the heel?
Mary - Reply Share
I have just added a comment to help with this
Awethentique Pty Ltd - Reply Share
Past 24 Hours: 13
Past 7 Days: 124
Past 30 Days: 721
All Time: 101,421
