Health o Meter HDR743 Wire Connection Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
68
All Time:
595
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Health o Meter HDR743 Wire Connection Replacement, Wire Connection: step 1, image 1 of 1
      • Use a voltmeter to check for power in the wires.
      • If the power is on, the voltmeter will give a reading. Verify if the red indicator light is visible.
      Ask FixBot
    2. Health o Meter HDR743 Wire Connection Replacement: step 2, image 1 of 1
      • Identify where the issue in the wire begins.
      • If the problem isn't near a connection, use wire strippers to cut away the troubled area, and splice a new wire in-between.
      • If the troubled area cannot be found, the entire wire will need to be replaced.
      • Use a soldering iron to remove the wire from its connection to the circuit board.
      • Use wire strippers to remove the wires from the other components.
      Ask FixBot
    3. Health o Meter HDR743 Wire Connection Replacement: step 3, image 1 of 1
      • Use a soldering iron to solder and splice a new wire to the component.
      • The other end of the wire should be spliced or soldered directly to the circuit board.
      Ask FixBot
    4. Health o Meter HDR743 Wire Connection Replacement: step 4, image 1 of 1
      • Test the new connection with the voltmeter.
      • If the issue persists, the repair has failed, or a different component is faulty.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 68
All Time: 595
