Health o Meter HDR743 Power Supply Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
52
All Time:
559
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Health o Meter HDR743  Power Supply Replacement, Power Supply: step 1, image 1 of 1
      • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
      • If the the voltage at the power supply is incorrect, the power supply should be replaced.
      Ask FixBot
    2. Health o Meter HDR743  Power Supply Replacement: step 2, image 1 of 1
      • Use wire strippers to cut the wired connection to the power supply.
      • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
      Ask FixBot
    3. Health o Meter HDR743  Power Supply Replacement: step 3, image 1 of 1
      • Use the wire strippers to cut off the rubber ends of the power supply wires.
      • Use a soldering iron and solder to fuse the connections between the two wires.
      Ask FixBot
    4. Health o Meter HDR743  Power Supply Replacement: step 4, image 1 of 2 Health o Meter HDR743  Power Supply Replacement: step 4, image 2 of 2
      • Test the power supply once the wires have been reconnected.
      • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
      • If no issues are found, the circuit board may need to be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 52
All Time: 559
