Up to 20% off select tools
Headphone Jack Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
50
Past 30 Days:
302
All Time:
2,647
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
Have you ever had a loose wire or bad jack on your headphone? This guide will help you repair your headphone jack like a new one.
Before proceeding with the replacement, you need to be familiar with the parts as this will involve connecting the right parts with the right cables.
    1. Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 1
      • Have all of the tools and parts ready for use.
      Ask FixBot
    2. Headphone Jack Replacement: step 2, image 1 of 2 Headphone Jack Replacement: step 2, image 2 of 2
      • Cut off the old faulty headphone jack.
      • Use the wire strippers to strip off the outermost rubber sheathing to expose the individual cords inside.
      • Most headphones have 3 internal wires, sometimes 4.
      Ask FixBot
    3. Headphone Jack Replacement: step 3, image 1 of 2 Headphone Jack Replacement: step 3, image 2 of 2
      • Unscrew the new headphone jack casing.
      • Separate the wires.
      • If you can have it held, it will be easier for working with the soldering iron.
      Ask FixBot
    4. Headphone Jack Replacement: step 4, image 1 of 3 Headphone Jack Replacement: step 4, image 2 of 3 Headphone Jack Replacement: step 4, image 3 of 3
      • Begin adding solder to each of the contacts of the headphone jack.
      • Every so often wipe off the soldering iron on a piece of sponge/cloth.
      • Wipe off excess solder to keep it in good condition
      Ask FixBot
    5. Headphone Jack Replacement: step 5, image 1 of 2 Headphone Jack Replacement: step 5, image 2 of 2
      • Take the casing and thread it to the wire, make sure to put it right way around.
      • Trim excess wire. (optional)
      Ask FixBot
    6. Headphone Jack Replacement: step 6, image 1 of 3 Headphone Jack Replacement: step 6, image 2 of 3 Headphone Jack Replacement: step 6, image 3 of 3
      • Add solder to the ends of each of the wires.
      • Give it a few seconds to make sure it gets through the coating.
      Ask FixBot
    7. Headphone Jack Replacement: step 7, image 1 of 3 Headphone Jack Replacement: step 7, image 2 of 3 Headphone Jack Replacement: step 7, image 3 of 3
      • Solder the wire to the headphone jack.
      • Make sure each wire goes to the right connector.
      • Red and white wires connect to the signal. The remaining one connects the ground connector.
      Ask FixBot
    8. Headphone Jack Replacement: step 8, image 1 of 1
      • Use pliers to crimp the ground connection onto the wire to make it nice and secured.
      Ask FixBot
    9. Headphone Jack Replacement: step 9, image 1 of 2 Headphone Jack Replacement: step 9, image 2 of 2
      • Wrap around the contacts with electric tape to prevent shorts.
      • Move up the outer casing and screw it to the jack with pliers.
      Ask FixBot
    10. Headphone Jack Replacement: step 10, image 1 of 1
      • Test the headphone by plugging it into device.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
Chi Chung Yung
235 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 302
All Time: 2,647
