Head Cleaning v3
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
81
All Time:
1,039
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Head Cleaning v3
    1. Head Cleaning v3, Setting Up the Printer: step 1, image 1 of 2 Head Cleaning v3, Setting Up the Printer: step 1, image 2 of 2
      • With the printer switched on, access the menu screen and select the option "Quick Configuration".
      • In the Quick Configuration menu select the option "Back off the Table".
      Ask FixBot
    2. Head Cleaning v3, Repositing table: step 2, image 1 of 3 Head Cleaning v3, Repositing table: step 2, image 2 of 3 Head Cleaning v3, Repositing table: step 2, image 3 of 3
      • When the table reach the position indicated in the picture, press the Reset button on the left side of the machine as shown.
      • Select the option "Pre-heat PLA" in the Quick Configuration menu.
      Ask FixBot
    3. Head Cleaning v3, Repositioning the head: step 3, image 1 of 2 Head Cleaning v3, Repositioning the head: step 3, image 2 of 2
      • With the table in position push the head manually toward the machine center in order to obtain an easy handling.
      Ask FixBot
    4. Head Cleaning v3, Removing the nozzle: step 4, image 1 of 3 Head Cleaning v3, Removing the nozzle: step 4, image 2 of 3 Head Cleaning v3, Removing the nozzle: step 4, image 3 of 3
      • Position the 17mm Fixed Key as indicated in the picture, locking the inner part of the head to prevent the nozzle head from turning.
      • WIth the 7mm wrench take off the nozzle head.
      Ask FixBot
    5. Head Cleaning v3, Removing the upper PTFE: step 5, image 1 of 2 Head Cleaning v3, Removing the upper PTFE: step 5, image 2 of 2
      • With your hands, pull out the PTFE tube from the printhead by pressing the black piece of the part where the tube is seated
      Ask FixBot
    6. Head Cleaning v3, Removing the inner PTFE: step 6, image 1 of 3 Head Cleaning v3, Removing the inner PTFE: step 6, image 2 of 3 Head Cleaning v3, Removing the inner PTFE: step 6, image 3 of 3
      • By positioning the drill bit into the indicated hole, push it down until the inner PTFE comes out from under the head (where the nozzle hole is).
      Ask FixBot
    7. Head Cleaning v3, Replacement and cleaning: step 7, image 1 of 3 Head Cleaning v3, Replacement and cleaning: step 7, image 2 of 3 Head Cleaning v3, Replacement and cleaning: step 7, image 3 of 3
      • Finish removing the inner PTFE and replace it with a new one or clean it.
      • With the drill bit, clean the nozzle hole, as shown in the figure.
      • Insert the new inner PTFE in place as shown.
      Ask FixBot
    8. Head Cleaning v3, Reassembling the head: step 8, image 1 of 3 Head Cleaning v3, Reassembling the head: step 8, image 2 of 3 Head Cleaning v3, Reassembling the head: step 8, image 3 of 3
      • Replace the nozzle at the bottom of the printhead and the PTFE at the top, pushing it all the way with your hands.
      Ask FixBot
    9. Head Cleaning v3, Returning the table to start position: step 9, image 1 of 2 Head Cleaning v3, Returning the table to start position: step 9, image 2 of 2
      • Reposition the table in the "Home XYZ" menu option in the fast settings section and wait until it is in the position indicated by the figure
      Ask FixBot
You are ready to continue your impressions!
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Mousta Impressoras 3D
691 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 81
All Time: 1,039
