Hasee Z7M-i78172D1 Screen Replacement
    1. Hasee Z7M-i78172D1 Screen Replacement, Screen: step 1, image 1 of 2 Hasee Z7M-i78172D1 Screen Replacement, Screen: step 1, image 2 of 2
      • Remove the stickers covering the screws. These are located on both corners of the screen. (Two in total)
      • Remove the two 7mm screws.
      Ask FixBot
    2. Hasee Z7M-i78172D1 Screen Replacement: step 2, image 1 of 3 Hasee Z7M-i78172D1 Screen Replacement: step 2, image 2 of 3 Hasee Z7M-i78172D1 Screen Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to pull the plastic screen bezel forward.
      • Remove the 4 7mm screws in the corners holding the screen up.
      • Use a plastic oping tool to pry the screen forward. Lay it on the keyboard.
      Ask FixBot
    3. Hasee Z7M-i78172D1 Screen Replacement: step 3, image 1 of 2 Hasee Z7M-i78172D1 Screen Replacement: step 3, image 2 of 2
      • Peel off the tape that connects the chord to the screen.
      • Carefully unplug chord.
      Ask FixBot
Desiree Mora
304 Reputation
3 Guides authored
USF Tampa, Team S6-G6, Eyestone Spring 2018 Member of USF Tampa, Team S6-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S6G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 82
All Time: 2,165
