Hasbro Furby 2012 Switch Replacement
    1. Hasbro Furby 2012 Switch Replacement, Outer Shell: step 1, image 1 of 3 Hasbro Furby 2012 Switch Replacement, Outer Shell: step 1, image 2 of 3 Hasbro Furby 2012 Switch Replacement, Outer Shell: step 1, image 3 of 3
      • Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
      Ask FixBot
    2. Hasbro Furby 2012 Switch Replacement: step 2, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 2, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 2, image 3 of 3
      • Use a Phillips #0 driver to unscrew the eight 10mm screws.
      • Remove the base ring after unscrewing all the screws.
      • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
      Ask FixBot
    3. Hasbro Furby 2012 Switch Replacement: step 3, image 1 of 2 Hasbro Furby 2012 Switch Replacement: step 3, image 2 of 2
      • Unhook the white ribbon from the tab on the base.
      Ask FixBot
    4. Hasbro Furby 2012 Switch Replacement: step 4, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 4, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 4, image 3 of 3
      • Roll the Furby's fur downward.
      • Disconnect the now exposed red wire.
      Ask FixBot
    5. Hasbro Furby 2012 Switch Replacement: step 5, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 5, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 5, image 3 of 3
      • Locate the two middle clips first.
      • Locate the two remaining clips on Furby's sides, they are opposite each other.
      • Orient the Furby upside down with the tail facing away from you.
      Ask FixBot
    6. Hasbro Furby 2012 Switch Replacement: step 6, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 6, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 6, image 3 of 3
      • Insert a metal prying tool directly into the clip opening.
      • Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
      • Repeat the previous step to remove the remaining three clips.
      Ask FixBot
    7. Hasbro Furby 2012 Switch Replacement: step 7, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 7, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 7, image 3 of 3
      • Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
      • Lift up on the fur covering until the face of the Furby is exposed.
      Ask FixBot
    8. Hasbro Furby 2012 Switch Replacement: step 8, image 1 of 3 Hasbro Furby 2012 Switch Replacement: step 8, image 2 of 3 Hasbro Furby 2012 Switch Replacement: step 8, image 3 of 3
      • Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
      • Lift tape gently and peel back until the tape is nearly removed.
      • Do not pull on the yellow wire located on the opposite end of the tape.
      Ask FixBot
    9. Hasbro Furby 2012 Switch Replacement: step 9, image 1 of 2 Hasbro Furby 2012 Switch Replacement: step 9, image 2 of 2
      • Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
      • Remove the 10mm screws with the Phillips#0 screwdriver.
      Ask FixBot
    10. Hasbro Furby 2012 Switch Replacement: step 10, image 1 of 1
      • Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
      • Peel the tape up until it is nearly detached from the black case.
      Ask FixBot
    11. Hasbro Furby 2012 Switch Replacement: step 11, image 1 of 2 Hasbro Furby 2012 Switch Replacement: step 11, image 2 of 2
      • Orient the Furby face down, with the base facing away from you.
      • Locate the clips below the ears.
      • Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
      Ask FixBot
    12. Hasbro Furby 2012 Switch Replacement: step 12, image 1 of 2 Hasbro Furby 2012 Switch Replacement: step 12, image 2 of 2
      • Remove the loose, plastic back panel by pulling the panel away from Furby's body.
      Ask FixBot
    1. Hasbro Furby 2012 Switch Replacement, Switch: step 13, image 1 of 2 Hasbro Furby 2012 Switch Replacement, Switch: step 13, image 2 of 2
      • Locate and remove the two screws holding in the switch using J0 Phillips Head Screw Driver.
      Ask FixBot
    2. Hasbro Furby 2012 Switch Replacement: step 14, image 1 of 2 Hasbro Furby 2012 Switch Replacement: step 14, image 2 of 2
      Tool used on this step:
      Buy
      • Orient the Furby with the beak facing right.
      • Using the blunt and pointed tweezers, remove the black connector.
      • Insert the new switch in place of where the previous connector was located.
      Ask FixBot
2 other people completed this guide.
Jordan Castillo
1,063 Reputation
5 Guides authored
Cal Poly, Team 15-5, Livingston Fall 2016 Member of Cal Poly, Team 15-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G5
4 Members
72 Guides authored
1 Guide Comment
Did someone find a replacement furby switch? Or found a way to repair the one inside the furby already?
Frubyx - Reply Share
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 41
All Time: 2,188
