Hasbro Bop-It Micro Series Buttons Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
97
All Time:
2,888
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If the game is turned on but the Bop-It button(s) does not work, this is because the button inside the device that provides functionality may be broken. To effectively replace them see this step-by-step guide.
Tools
    1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: step 1, image 1 of 1
      • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
      Ask FixBot
    2. Hasbro Bop-It Micro Series Buttons Replacement: step 2, image 1 of 1
      • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
      • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
      Ask FixBot
    3. Hasbro Bop-It Micro Series Buttons Replacement: step 3, image 1 of 1
      • Carefully separate the two sections, leaving them connected by the wires.
      Ask FixBot
    1. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: step 4, image 1 of 1
      • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
      Ask FixBot
    2. Hasbro Bop-It Micro Series Buttons Replacement: step 5, image 1 of 1
      • After removing the buttons, solder new, operational buttons back into place.
      Ask FixBot
3 other people completed this guide.
Glenn Haag
491 Reputation
3 Guides authored
IUPUI, Team 3-1, Harley Fall 2016 Member of IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 2,888
