Harman Kardon Invoke Microphone on/off Button Replacement
  1. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: step 1, image 1 of 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: step 1, image 2 of 2
    • Use a metal spudger to remove the rubber bottom.
    Ask FixBot
  2. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: step 2, image 1 of 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base screws: step 2, image 2 of 2
    • Use a Torx #10 screwdriver to remove the four 14.0 mm screws.
    Ask FixBot
  3. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: step 3, image 1 of 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the base: step 3, image 2 of 2
    • Firmly grip the bottom and wiggle it upwards to remove the base.
    Ask FixBot
  4. Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: step 4, image 1 of 2 Harman Kardon Invoke Microphone on/off Button Replacement, Unscrew the board: step 4, image 2 of 2
    • Use a Torx #10 screwdriver to remove three 10.0 mm screws from the highlighted board attached to microphone button.
    Ask FixBot
  5. Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: step 5, image 1 of 2 Harman Kardon Invoke Microphone on/off Button Replacement, Remove the board: step 5, image 2 of 2
    • Pull the cable lightly to disconnect the button board from device.
    • To replace the microphone button, you will have to replace the entire smaller board.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 17
All Time: 876
