Harman Kardon Esquire Mini Front Panel Replacement
    1. Harman Kardon Esquire Mini Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
      • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
      Ask FixBot
    2. Harman Kardon Esquire Mini Front Panel Replacement: step 2, image 1 of 1
      • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
      • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
      • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
      Ask FixBot
yousef aljeemaz
1,066 Reputation
5 Guides authored
USF Tampa, Team S1-G9, Cagle Fall 2017 Member of USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,050
