Harley-Davidson Fatboy Lo Battery Replacement
  1. Harley-Davidson Fatboy Lo Battery Replacement, Battery: step 1, image 1 of 2 Harley-Davidson Fatboy Lo Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the screw using the flathead screwdriver.
    • Following removal of the screw, lift the seat from the rear and then carefully pull the seat towards the back of the bike removing it.
    Ask FixBot
  2. Harley-Davidson Fatboy Lo Battery Replacement: step 2, image 1 of 1
    • The battery is located at the center of the frame, directly beneath the seat.
    Ask FixBot
  3. Harley-Davidson Fatboy Lo Battery Replacement: step 3, image 1 of 2 Harley-Davidson Fatboy Lo Battery Replacement: step 3, image 2 of 2
    • To disconnect the terminals you will use a ratchet and 10mm socket to remove the bolts, then remove the wires from each terminal.
    • Be sure to disconnect the ground before the positive connection. (Note: the positive is covered by a red plastic cover, this must be removed to expose the terminal.)
    Ask FixBot
  4. Harley-Davidson Fatboy Lo Battery Replacement: step 4, image 1 of 1
    • Once the wires are disconnected from the terminals carefully remove the battery, by grasping the battery and gently lifting from its base.
    Ask FixBot
  5. Harley-Davidson Fatboy Lo Battery Replacement: step 5, image 1 of 1
    • Ensure that the positive terminal is on the left side of the bike and the negative terminal is on the right.
    • Gently place the battery back onto the base avoiding any wires.
    Ask FixBot
  6. Harley-Davidson Fatboy Lo Battery Replacement: step 6, image 1 of 2 Harley-Davidson Fatboy Lo Battery Replacement: step 6, image 2 of 2
    • Reconnect the terminals by placing the wires over the designated terminals.
    • Positive before Ground.
    • Once the wires are in place tighten the screws back in place using the ratchet wrench and 10mm socket.
    Ask FixBot
  7. Harley-Davidson Fatboy Lo Battery Replacement: step 7, image 1 of 1
    • Cover the positive terminal with the red plastic covering provided.
    Ask FixBot
  8. Harley-Davidson Fatboy Lo Battery Replacement: step 8, image 1 of 2 Harley-Davidson Fatboy Lo Battery Replacement: step 8, image 2 of 2
    • To replace the seat, place the metal tab, on the bottom side at the front of the seat into the slot at the base of the fuel tank.
    • Ensuring the tab is in place, repeat step 1 in reverse to reinstall the seat.
    Ask FixBot
This is a comprehensive guide that walks through the removal of the old battery to the installation of the new.
Austin Stone
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 150
All Time: 13,084
