Up to 20% off select tools
Hard Drive Replacement Guide
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
90
All Time:
1,421
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is for replacing the hard drive on a Gateway LT2104u Laptop.
    1. Hard Drive Replacement Guide, Hard Drive: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to loosen the screws.
      • The screws are designed to remain in the panel.
      Ask FixBot
    2. Hard Drive Replacement Guide: step 2, image 1 of 3 Hard Drive Replacement Guide: step 2, image 2 of 3 Hard Drive Replacement Guide: step 2, image 3 of 3
      • To open the panel, use a plastic opening tool or your finger.
      • If there is difficulty opening the panel, than the screws may not be lose enough.
      Ask FixBot
    3. Hard Drive Replacement Guide: step 3, image 1 of 2 Hard Drive Replacement Guide: step 3, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew the two 5mm screws.
      • Remove the hard drive by using your fingers to pull firmly on the clear tab.
      Ask FixBot
    4. Hard Drive Replacement Guide: step 4, image 1 of 1
      • You have successfully removed the hard drive from the laptop.
      Ask FixBot
Author
with
Steven Park
420 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 90
All Time: 1,421
