Hannspree SN12E2 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
61
All Time:
656
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the RAM in the Hannspree SN12E2 laptop. RAM is to run applications on your device if your device is stalling or running low or even crashing all together this may be the solution.
Tools
    1. Hannspree SN12E2 RAM Replacement, Battery: step 1, image 1 of 1
      • Unplug and power off your laptop.
      Ask FixBot
    2. Hannspree SN12E2 RAM Replacement: step 2, image 1 of 1
      • Close your laptop .
      • Place your laptop face down on a flat surface.
      Ask FixBot
    3. Hannspree SN12E2 RAM Replacement: step 3, image 1 of 3 Hannspree SN12E2 RAM Replacement: step 3, image 2 of 3 Hannspree SN12E2 RAM Replacement: step 3, image 3 of 3
      • Unlatch the lock on the top right of your laptop first.
      • You will need to pull on the lock on the left side and remove the battery at the same time
      • The left lock is a spring lock and needs constant pressure applied in order to stay open.
      Ask FixBot
    1. Hannspree SN12E2 RAM Replacement, RAM: step 4, image 1 of 2 Hannspree SN12E2 RAM Replacement, RAM: step 4, image 2 of 2
      • Remove the RAM access door.
      • Remove the two 3mm screws using a Phillips #0 screwdriver.
      • Gently lift on the door out of place.
      • When replacing the door it should click into place. Ensure the alignment tabs are correctly seated and gently push until it clicks into place.
      Ask FixBot
    2. Hannspree SN12E2 RAM Replacement: step 5, image 1 of 3 Hannspree SN12E2 RAM Replacement: step 5, image 2 of 3 Hannspree SN12E2 RAM Replacement: step 5, image 3 of 3
      • Gently push outward on the two retaining clips, being careful not to damage the motherboard.
      • Lift up on the RAM until it makes a 35 degree angle with the board.
      • Remove the RAM by pulling away from the housing at 35 degrees.
      Ask FixBot
Tim Chase
363 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 61
All Time: 656
