Handspring Visor Edge Button Board Replacement
    1. Handspring Visor Edge Button Board Replacement, Flip Cover: step 1, image 1 of 2 Handspring Visor Edge Button Board Replacement, Flip Cover: step 1, image 2 of 2
      • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
      • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
      • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
      • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
      Ask FixBot
    1. Handspring Visor Edge Button Board Replacement, Back Panel: step 2, image 1 of 1
      • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
      Ask FixBot
    2. Handspring Visor Edge Button Board Replacement: step 3, image 1 of 1
      • Remove the gray back plate from the PDA.
      Ask FixBot
    3. Handspring Visor Edge Button Board Replacement: step 4, image 1 of 2 Handspring Visor Edge Button Board Replacement: step 4, image 2 of 2
      • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
      • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
      Ask FixBot
    4. Handspring Visor Edge Button Board Replacement: step 5, image 1 of 2 Handspring Visor Edge Button Board Replacement: step 5, image 2 of 2
      • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
      Ask FixBot
    5. Handspring Visor Edge Button Board Replacement: step 6, image 1 of 1
      • Gently remove the white frame from the back of the PDA.
      Ask FixBot
    1. Handspring Visor Edge Button Board Replacement, Button Board: step 7, image 1 of 1
      • Lift the metal cover from the phone to remove it.
      Ask FixBot
    2. Handspring Visor Edge Button Board Replacement: step 8, image 1 of 1
      • Gently pull the button pad off the device.
      Ask FixBot
Nick Lazarakis
334 Reputation
3 Guides authored
Cal Poly, Team 11-28, Maness Winter 2011 Member of Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 112
All Time: 1,304
