Handspring Visor Edge Battery Replacement
    1. Handspring Visor Edge Battery Replacement, Flip Cover: step 1, image 1 of 2 Handspring Visor Edge Battery Replacement, Flip Cover: step 1, image 2 of 2
      • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
      • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
      • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
      • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
      Ask FixBot
    1. Handspring Visor Edge Battery Replacement, Back Panel: step 2, image 1 of 1
      • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
      Ask FixBot
    2. Handspring Visor Edge Battery Replacement: step 3, image 1 of 1
      • Remove the gray back plate from the PDA.
      Ask FixBot
    3. Handspring Visor Edge Battery Replacement: step 4, image 1 of 2 Handspring Visor Edge Battery Replacement: step 4, image 2 of 2
      • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
      • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
      Ask FixBot
    4. Handspring Visor Edge Battery Replacement: step 5, image 1 of 2 Handspring Visor Edge Battery Replacement: step 5, image 2 of 2
      • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
      Ask FixBot
    5. Handspring Visor Edge Battery Replacement: step 6, image 1 of 1
      • Gently remove the white frame from the back of the PDA.
      Ask FixBot
    1. Handspring Visor Edge Battery Replacement, Battery: step 7, image 1 of 1
      • Gently pull off the front cover.
      Ask FixBot
    2. Handspring Visor Edge Battery Replacement: step 8, image 1 of 2 Handspring Visor Edge Battery Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Gently use your finger or tweezers to push the brown lock away from the side of the circuit board that is holding the ribbon cable.
      • Remove the ribbon cable with tweezers.
      Ask FixBot
    3. Handspring Visor Edge Battery Replacement: step 9, image 1 of 1
      • Using the tweezers, pull back the ribbon cable on the top of the device.
      • Pull at the white part of the ribbon to avoid tearing.
      Ask FixBot
    4. Handspring Visor Edge Battery Replacement: step 10, image 1 of 1
      • Using the same technique as with the other ribbons, locate and disconnect the ribbon cable above the battery pack.
      Ask FixBot
    5. Handspring Visor Edge Battery Replacement: step 11, image 1 of 1
      • All the ribbon cables should be disconnected from the mother board.
      • Remove the four 3.6 mm Phillips #00 screws located at each corner of the device.
      Ask FixBot
    6. Handspring Visor Edge Battery Replacement: step 12, image 1 of 2 Handspring Visor Edge Battery Replacement: step 12, image 2 of 2
      • Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
      • Be careful not to break the soldered wires that connects the circuit board to the battery pack.
      • Disconnect the wire that connects the battery pack to the motherboard using tweezers.
      Ask FixBot
    7. Handspring Visor Edge Battery Replacement: step 13, image 1 of 2 Handspring Visor Edge Battery Replacement: step 13, image 2 of 2
      • Wedge the spudger under the battery to pry it apart from the adhesive.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Christian Valoria
229 Reputation
2 Guides authored
Cal Poly, Team 11-28, Maness Winter 2011 Member of Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 117
All Time: 4,238
