Up to 20% off select tools
Handspring Visor Edge Back Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,832
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Handspring Visor Edge Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
      Ask FixBot
    2. Handspring Visor Edge Back Panel Replacement: step 2, image 1 of 1
      • Remove the gray back plate from the PDA.
      Ask FixBot
    3. Handspring Visor Edge Back Panel Replacement: step 3, image 1 of 2 Handspring Visor Edge Back Panel Replacement: step 3, image 2 of 2
      • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
      • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
      Ask FixBot
    4. Handspring Visor Edge Back Panel Replacement: step 4, image 1 of 2 Handspring Visor Edge Back Panel Replacement: step 4, image 2 of 2
      • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
      Ask FixBot
    5. Handspring Visor Edge Back Panel Replacement: step 5, image 1 of 1
      • Gently remove the white frame from the back of the PDA.
      Ask FixBot
Author
with
Nick Lazarakis
334 Reputation
3 Guides authored
Cal Poly, Team 11-28, Maness Winter 2011 Member of Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,832
