Up to 20% off select tools
Handheld Shower Head Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
36
Past 30 Days:
183
All Time:
2,251
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Shower heads must be replaced every 6-8 months to avoid sediment buildup and ensure efficient water flow.
As such, this guide aims to explain how to replace a handheld showerhead where any model is applicable in the procedural steps that follow.
Prior to following this guide, it is important to understand the slight risk of injury with this repair in terms of wet surfaces. Overall, this procedure involves little to no possibility for injury but caution should be advised and shoes with good traction can be utilized to avoid slipping while performing the replacement.
It is also important to note that water should be turned off before following the procedure outlined below.
    1. Handheld Shower Head Replacement, Shower Head: step 1, image 1 of 1
      • Obtain a replacement showerhead.
      • Modern shower heads and arms are usually compatible with any shower located in the US and Canada. Restrictions may include antique (older than 1994) and other uncommon showers.
      Ask FixBot
    2. Handheld Shower Head Replacement: step 2, image 1 of 1
      • Unscrew the nut attached to the shower head connected to the wall using a wrench.
      Ask FixBot
    3. Handheld Shower Head Replacement: step 3, image 1 of 3 Handheld Shower Head Replacement: step 3, image 2 of 3 Handheld Shower Head Replacement: step 3, image 3 of 3
      • Unpack the new showerhead. Take note of the type of attachment and what tool you might need to tighten it.
      • Be sure to check with the included manual whether or not you will need thread seal tape, as some showers do not require it.
      • If you need to use Thread Seal Tape, make sure to wrap it with the direction of the threading, so it stays smooth and aligned as you thread the ends together.
      Ask FixBot
    4. Handheld Shower Head Replacement: step 4, image 1 of 2 Handheld Shower Head Replacement: step 4, image 2 of 2
      • Attach the nut that threads to the arm of the pipe in the wall loosely; hand-tightening everything for now is fine.
      Ask FixBot
    5. Handheld Shower Head Replacement: step 5, image 1 of 2 Handheld Shower Head Replacement: step 5, image 2 of 2
      • Attach the ball jointed segment to the attaching nut, with the nut’s threaded end towards the shower head, facing away from where the ball component was screwed onto the pipe.
      • Ensure that the rubber or plastic washer is in place to prevent leaks in the future.
      Ask FixBot
    6. Handheld Shower Head Replacement: step 6, image 1 of 2 Handheld Shower Head Replacement: step 6, image 2 of 2
      • Attach the piece that holds the shower head and attaches to the pipe to the threaded nut over the ball joint.
      Ask FixBot
    7. Handheld Shower Head Replacement: step 7, image 1 of 1
      • Attach the water hose to the ball joint component, and then to the base of the showerhead.
      • You can place the showerhead in its holding slot for convenience as you attach the line.
      Ask FixBot
    8. Handheld Shower Head Replacement: step 8, image 1 of 1
      • Finish tightening all components properly with your wrench (do not over-tighten).
      • Tighten down the nut encasing the ball-jointed segment until it will not move or slip on its own, but is loose enough to be gently adjusted with minimal force. This component will most likely not require the wrench, as it is built to be adjusted.
      Ask FixBot
    9. Handheld Shower Head Replacement: step 9, image 1 of 1
      • Run the water through the showerhead to test for leaks, and tighten or loosen components as necessary.
      • Ensure the ball joint pivots easily in the socket. If it does not, loosen the nut around the ball until it can move (without adjusting the other components).
      Ask FixBot
Finish Line
Author
with
Aaliyah Kahoohanohano-Davis
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 183
All Time: 2,251
