Hand-Held Blender Motor Replacement
    1. Hand-Held Blender Motor Replacement, Motor: step 1, image 1 of 1
      • Place the product on a clean and empty surface.
      Ask FixBot
    2. Hand-Held Blender Motor Replacement: step 2, image 1 of 1
      • Twist the attachment with the blades from the base of the blender.
      Ask FixBot
    3. Hand-Held Blender Motor Replacement: step 3, image 1 of 1
      • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
      Ask FixBot
    4. Hand-Held Blender Motor Replacement: step 4, image 1 of 1
      • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
      Ask FixBot
    5. Hand-Held Blender Motor Replacement: step 5, image 1 of 1
      • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
      • This reveals the motor.
      Ask FixBot
    6. Hand-Held Blender Motor Replacement: step 6, image 1 of 1
      • Lift the motor out of the casing.
      • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
      Ask FixBot
    7. Hand-Held Blender Motor Replacement: step 7, image 1 of 1
      • With a soldering iron disconnect the wires coming from the motor from the PCB.
      • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Model WST2024E blender counter model. Heavey glass 1.5 Liter. 3 SPD. plus pulse.
Need to either replace brushes or motor
T.A. MacMillan - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 92
All Time: 5,304
