Up to 20% off select tools
Hamilton-T1 Battery Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
124
All Time:
3,067
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
If you need to replace the optional second, hot swappable battery in your Hamilton-T1 ventilators, follow this guide. The hot-swappable battery is a secondary battery that provides power to the Hamilton-T1 ventilator when the standard primary battery runs out of charge or there is no external AC/DC power source available. This is a simple replacement to swap out the old battery with a charged battery. There are no tools involved.
    1. Hamilton-T1 Battery Replacement, Battery: step 1, image 1 of 2 Hamilton-T1 Battery Replacement, Battery: step 1, image 2 of 2
      • Use the handle on the left side of the front panel to pull the cover off.
      Ask FixBot
    2. Hamilton-T1 Battery Replacement: step 2, image 1 of 1
      • Locate the metal lock clip above the battery on the left-hand side.
      • Turn the metal lock clip to the left and all the way up.
      • This will allow access to the battery.
      Ask FixBot
    3. Hamilton-T1 Battery Replacement: step 3, image 1 of 1
      • Pull the white tab on the end of the battery to pull it out of the slot.
      Ask FixBot
      • Insert the replacement battery by holding onto the white tab and sliding it into the empty slot.
      • The Hamilton Medical logo needs to be facing up.
      Ask FixBot
    4. Hamilton-T1 Battery Replacement: step 5, image 1 of 1
      • Turn the metal locking clip down and to the right, until it forms a straight line.
      Ask FixBot
      • Close the cover.
      Ask FixBot
Author
with
Amanda Olla
255 Reputation
1 Guide authored
Cal Poly, Team S11-G24, Paton Spring 2020 Member of Cal Poly, Team S11-G24, Paton Spring 2020
CPSU-PATON-S20S11G24
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 124
All Time: 3,067
