Up to 20% off select tools
Hamilton-C3 Fan Filter Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
56
All Time:
533
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
Use this guide to replace the cooling fan filter on a Hamilton-C3 ventilator.
The fan filter prevents dust and other coarse particulates from getting blown into and damaging the internals of the ventilator. It should be checked for dust and lint every month (or more often, if necessary) and cleaned or replaced if needed.
A neglected fan filter can cause overheating if it becomes clogged to the point where an insufficient amount of air can be drawn through it by the cooling fan. Inconsistent maintenance of the fan filter can also increase the risk of patient cross-contamination.
For more information on replacing the fan filter, please refer to page 201 in the operator’s manual.
    1. Hamilton-C3 Fan Filter Replacement, Fan Filter: step 1, image 1 of 2 Hamilton-C3 Fan Filter Replacement, Fan Filter: step 1, image 2 of 2
      • Remove the back panel/filter cover (labeled with 3 in the diagram).
      Ask FixBot
    2. Hamilton-C3 Fan Filter Replacement: step 2, image 1 of 2 Hamilton-C3 Fan Filter Replacement: step 2, image 2 of 2
      • Remove the fan filter.
      • The second image shows what a fan filter should look like.
      • During reassembly, install a new fan filter or wash the existing filter in a mild soap solution, rinse it, dry it, and reinstall it.
      Ask FixBot
Author
with
Calder Wood
270 Reputation
2 Guides authored
Cal Poly, Team S7-G1, Paton Spring 2020 Member of Cal Poly, Team S7-G1, Paton Spring 2020
CPSU-PATON-S20S7G1
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 533
