Up to 20% off select tools
Hamilton-C3 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
65
All Time:
1,261
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery for the Hamilton-C3 Ventilator. There are multiple alarms and indicators that the ventilator uses to signal that its battery is either low or dead. Some of these alarms are identified in the Hamilton-C3 troubleshooting page.
The lithium battery provided by Hamilton Medical is 10.8 V, 6.7 Ah, 72 Wh, and 50 W typical. The typical lifetime of the ventilator without external power running on one battery is about 3.5 hours, and for two batteries 7.5 hours.
For more information on replacing the battery, please refer to page 202 in the operator’s manual.
    1. Hamilton-C3 Battery Replacement, Battery: step 1, image 1 of 1
      • Connect the ventilator to an external power source. There is a two-prong cable that can be connected to a port on the backside of the ventilator.
      • It is vital that external power is present so that ventilation may continue even without a working battery in place.
      Ask FixBot
    2. Hamilton-C3 Battery Replacement: step 2, image 1 of 2 Hamilton-C3 Battery Replacement: step 2, image 2 of 2
      • Open the battery door on the left side (facing the moniter) of the ventilator.
      Ask FixBot
    3. Hamilton-C3 Battery Replacement: step 3, image 1 of 1
      • Twist the metal locking clip (indicated by red arrow) counterclockwise out of the locking position.
      • Use any flathead screwdriver to accomplish this task.
      • During reassembly, turn the metal locking clip (in red) clockwise, back into the locked position, to keep the battery secure.
      • Push the latch (component in red) upwards.
      Ask FixBot
    4. Hamilton-C3 Battery Replacement: step 4, image 1 of 1
      • While pushing up the retaining clip, remove the battery (follow the blue arrow, ignore the white arrow).
      • During reassembly, push the new battery in until the latch (circled in red) locks down.
      Ask FixBot
    5. Hamilton-C3 Battery Replacement: step 5, image 1 of 1
      • Turn the metal locking clip (in red) clockwise back into the locked position to keep the battery secure.
      Ask FixBot
Author
with
Lucas Rasmussen
2,375 Reputation
11 Guides authored
Cal Poly, Team S7-G1, Paton Spring 2020 Member of Cal Poly, Team S7-G1, Paton Spring 2020
CPSU-PATON-S20S7G1
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 65
All Time: 1,261
