Hamilton G5 Safety Valve Block Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
64
All Time:
393
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
For more information on removing the safety valve block, please refer to section 10 in the service manual.
    1. Hamilton G5 Safety Valve Block Replacement, Rail: step 1, image 1 of 1
      • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
      Ask FixBot
    2. Hamilton G5 Safety Valve Block Replacement: step 2, image 1 of 1
      • Remove the Rail (B).
      Ask FixBot
    3. Hamilton G5 Safety Valve Block Replacement: step 3, image 1 of 1
      • The Standoff Brackets (C) remain with the Main Cover.
      Ask FixBot
      • Place aside in a safe location.
      Ask FixBot
    1. Hamilton G5 Safety Valve Block Replacement, Main Cover: step 5, image 1 of 1
      • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
      Ask FixBot
      Ask FixBot
    1. Hamilton G5 Safety Valve Block Replacement, Safety Valve Block: step 7, image 1 of 1
      • Remove Safety Valve Block
      • 1. Disconnect the cable from the Ambient Valve Solenoid
      • 2. Disconnect the Shaped Hose (A)
      • 3. Remove the 2 Hex Allen Screws (B)
      • 4. Remove the Safety Valve Block
      • To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
      Ask FixBot
William
145 Reputation
2 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 64
All Time: 393
