Up to 20% off select tools
Hamilton G5 Nebulizer Valve Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
55
All Time:
666
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Parts
Tools
Introduction
Go to step 1 ↓
This guide serves as a step-by-step replacement tutorial in replacing the internal nebulizer. First you will need to remove the rail and main cover shown in separate guides. You will need a phillips-head screwdriver and a hex-allen wrench to complete the replacement. It will take about 15-20 minutes.
For more information on replacing the nebulizer, please refer to section 10 in the service manual.
    1. Hamilton G5 Nebulizer Valve Replacement, Rail: step 1, image 1 of 1
      • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
      Ask FixBot
    2. Hamilton G5 Nebulizer Valve Replacement: step 2, image 1 of 1
      • Remove the Rail (B).
      Ask FixBot
    3. Hamilton G5 Nebulizer Valve Replacement: step 3, image 1 of 1
      • The Standoff Brackets (C) remain with the Main Cover.
      Ask FixBot
      • Place aside in a safe location.
      Ask FixBot
    1. Hamilton G5 Nebulizer Valve Replacement, Main Cover: step 5, image 1 of 1
      • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
      Ask FixBot
      Ask FixBot
    1. Hamilton G5 Nebulizer Valve Replacement, Nebulizer Valve: step 7, image 1 of 1
      • After the rail and main cover are taken off, remove the dark blue tubing connected to the nebulizer, pictured here.
      Ask FixBot
    2. Hamilton G5 Nebulizer Valve Replacement: step 8, image 1 of 1
      • Remove the two phillips screws labeled A from the Nebulizer valve.
      Ask FixBot
    3. Hamilton G5 Nebulizer Valve Replacement: step 9, image 1 of 1
      • Remove the nebulizer valve parts.
      • The Nebulizer Valve parts are:B. Straight fitting
      • C. Front Nozzle fitting
      • D. Elbow fitting
      • E. Mounting bracket
      • F. Hex Allen screw for attaching the bracket to the Safety Valve Block
      Ask FixBot
Author
with
Cole Korchek
133 Reputation
1 Guide authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 55
All Time: 666
