Hamilton G5 Internal and Extended Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
77
All Time:
1,540
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
If your Hamilton G5 Ventilator has battery warnings, use these steps to replace either the internal or extended battery. The internal battery is 12V/120W, while the extended battery is 11-14V/95W. Before replacing a battery, it is important to run checks to ensure they do need to be replaced. Be cautious, as there is a large amount of power in them and there are many small parts involved. Before starting, make sure the ventilator is powered off and unplugged. To replace the battery, you will need an Allen Wrench.
For more information about replacing the battery, please refer to section 10 in the service manual.
    1. Hamilton G5 Internal and Extended Battery Replacement, Rail: step 1, image 1 of 1
      • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
      Ask FixBot
    2. Hamilton G5 Internal and Extended Battery Replacement: step 2, image 1 of 1
      • Remove the Rail (B).
      Ask FixBot
    3. Hamilton G5 Internal and Extended Battery Replacement: step 3, image 1 of 1
      • The Standoff Brackets (C) remain with the Main Cover.
      Ask FixBot
      • Place aside in a safe location.
      Ask FixBot
    1. Hamilton G5 Internal and Extended Battery Replacement, Main Cover: step 5, image 1 of 1
      • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
      Ask FixBot
      Ask FixBot
    1. Hamilton G5 Internal and Extended Battery Replacement, Internal and Extended Battery: step 7, image 1 of 1
      • Unscrew the 4 Hex Allen M4x8 screws (A), 2 on each side of the cover.
      • Lower the Front Cover (B) to remove it.
      • Disconnect the Alarm Status Display Connector (D) and set aside.
      Ask FixBot
    2. Hamilton G5 Internal and Extended Battery Replacement: step 8, image 1 of 1
      • Remove the 8 Hex Allen screws M4x8 (A) located on the side of the ventilator.
      • Locate internal battery (B) and slide it out.
      • Disconnect battery cable (C) and fully remove battery assembly.
      Ask FixBot
    3. Hamilton G5 Internal and Extended Battery Replacement: step 9, image 1 of 1
      • Remove 2 Hex Nuts, Washers, (D) and Cross Bar (E) from assembly.
      • Slide internal battery out from battery assembly.
      Ask FixBot
    4. Hamilton G5 Internal and Extended Battery Replacement: step 10, image 1 of 1
      • Extended Battery
      • Depress battery latch on right side (follow yellow arrow in image).
      • Slide the battery out of bracket to remove.
      Ask FixBot
Heidi Silk
139 Reputation
1 Guide authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 77
All Time: 1,540
