Hamilton G5 Inspiratory Valve Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. Hamilton G5 Inspiratory Valve Replacement, Rail: step 1, image 1 of 1
      • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
      Ask FixBot
    2. Hamilton G5 Inspiratory Valve Replacement: step 2, image 1 of 1
      • Remove the Rail (B).
      Ask FixBot
    3. Hamilton G5 Inspiratory Valve Replacement: step 3, image 1 of 1
      • The Standoff Brackets (C) remain with the Main Cover.
      Ask FixBot
      • Place aside in a safe location.
      Ask FixBot
    1. Hamilton G5 Inspiratory Valve Replacement, Main Cover: step 5, image 1 of 1
      • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
      Ask FixBot
      Ask FixBot
    1. Hamilton G5 Inspiratory Valve Replacement, Safety Valve Block: step 7, image 1 of 1
      • Remove Safety Valve Block
      • 1. Disconnect the cable from the Ambient Valve Solenoid
      • 2. Disconnect the Shaped Hose (A)
      • 3. Remove the 2 Hex Allen Screws (B)
      • 4. Remove the Safety Valve Block
      • To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
      Ask FixBot
    1. Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: step 8, image 1 of 2 Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: step 8, image 2 of 2
      • Removing the Inspiration Valve
      • 1. Disconnect the tubing and cables form the Inspiration Valve
      • 3. Remove 2 Hex Allen screws (B) M5x60
      • 4. Move the Inspiration Valve forward and then up
      • 5. Remove the Inspiration Valve
      Ask FixBot
William
145 Reputation
2 Guides authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
132 Guides authored
1 Guide Comment
wow great manual! very helpful and informative!
William - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 585
