Up to 20% off select tools
Hamilton G5 Fan Filter Replacement/Cleaning
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
58
All Time:
765
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
This guide is a replacement and cleaning tutorial for the fan filter. The fan filter can be found on the rear of the ventilation unit. It needs to be cleaned or replaced at least every month or more often. Check for dust and lint and if there is, clean or replace the fan filter. It is recommended to clean or replace between each patient to avoid cross-contamination.
For more information on replacing the fan filter, please refer to section 10 of the service manual.
    1. Hamilton G5  Fan Filter Replacement/Cleaning, Fan Filter: step 1, image 1 of 1
      • Remove the fan filter (A). No tools should be necessary.
      Ask FixBot
    2. Hamilton G5  Fan Filter Replacement/Cleaning: step 2, image 1 of 1
      • Replace with new filter or clean current filter.
      • To clean current filter, wash with a mild soap solution.
      • Rinse thoroughly. Dry completely before putting fan filter back.
      Ask FixBot
Author
with
Kaitlyn Anderson
85 Reputation
1 Guide authored
Cal Poly, Team S7-G25, Paton Spring 2020 Member of Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 58
All Time: 765
