Introduction
Replacement of the power cord. Make sure to keep the processor unplugged until finished with replacement.
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Tool used on this step:Heavy-Duty Spudger$4.99
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
From the open base pull the motor straight out.
