Hamilton Beach 70740 Power Cord Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Hamilton Beach 70740 Power Cord Replacement, Base Removal: step 1, image 1 of 3 Hamilton Beach 70740 Power Cord Replacement, Base Removal: step 1, image 2 of 3 Hamilton Beach 70740 Power Cord Replacement, Base Removal: step 1, image 3 of 3
      • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
      Ask FixBot
    2. Hamilton Beach 70740 Power Cord Replacement: step 2, image 1 of 2 Hamilton Beach 70740 Power Cord Replacement: step 2, image 2 of 2
      • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
      Ask FixBot
    3. Hamilton Beach 70740 Power Cord Replacement: step 3, image 1 of 1
      • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
      Ask FixBot
    4. Hamilton Beach 70740 Power Cord Replacement: step 4, image 1 of 1
      • Remove the screws indicated with a screw driver.
      Ask FixBot
    5. Hamilton Beach 70740 Power Cord Replacement: step 5, image 1 of 1
      • Remove the two screws behind the knob with a screwdriver.
      Ask FixBot
    1. Hamilton Beach 70740 Power Cord Replacement, Motor/Cord: step 6, image 1 of 1
      • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
      • Note that the plastic caps are glued
      Ask FixBot
    2. Hamilton Beach 70740 Power Cord Replacement: step 7, image 1 of 1
      • Remove the 4 screws located under the plastic caps with a screw driver.
      Ask FixBot
    3. Hamilton Beach 70740 Power Cord Replacement: step 8, image 1 of 2 Hamilton Beach 70740 Power Cord Replacement: step 8, image 2 of 2
      • Lift and remove the plastic gears at the center of the device.
      • Remove any grease residue underneath the plastic gears.
      Ask FixBot
    4. Hamilton Beach 70740 Power Cord Replacement: step 9, image 1 of 2 Hamilton Beach 70740 Power Cord Replacement: step 9, image 2 of 2
      • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
      Ask FixBot
    1. Hamilton Beach 70740 Power Cord Replacement, Power Cord: step 10, image 1 of 1
      • Solder the highlighted section of the power cord, and undo the wiring. Using soldering wire connect a new line with the soldering iron.
      • Learn more about soldering here.
      Ask FixBot
    2. Hamilton Beach 70740 Power Cord Replacement: step 11, image 1 of 1
      • Connect the other end of your power cord to the motor terminal.
      Ask FixBot
David Gedeon
806 Reputation
6 Guides authored
IUPUI, Team 1-1, Baechle Fall 2015 Member of IUPUI, Team 1-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 10
All Time: 578
